305/50r20 XL Load Rating VS E Rating
Jomax
Arizona
I plan on running toyoST 2s and still towing. Should get some by the end of summer. Guess I'll see how they do.
Black AOD
Ohio
I had a plan to lower my truck down well below stock height (assuming I kept it which I'm not going to now) and I was going to run my 22's on Toyo Proxes ST2 and see how they did as well, just nothing ridiculous on towing.
when you get into 22" rims that are 12" wide, it's impossible to find a good E load rated tire to run that's lower profile.
Jomax
Arizona
I'll still be towing 10k lbs. should be just fine.. #1 reason for tire blowouts is from age from what I've seen.
Black AOD
Ohio
10k isn't terrible though. That shouldn't be a whole helluva lot of tongue weight.
Heavy to me is anything 15k +
I agree, I think you'll be fine.
Jomax
Arizona
And once in a while a broken truck in which it'll be 14k.. I'm lowering my truck to fit in parking garages lol
Black AOD
Ohio
LOL. I was gonna lower mine down on 4800 lb springs and no rear block so it would fit in my garage and parking garages too haha
Jomax
Arizona
Yup, my truck is at 6ft7in stock. 90% of garages here in Ca are 6ft6..
Black AOD
Ohio
Yeah You have a 250 though. Mines a leveled stock height F350 and I just miss clearing 7 foot garages by about 3/4". Everything out here in the midwest seems to be 7'
Jomax
Arizona
Yeah, I vote lower yours!!
redneck1
Nor Cal
How much do 4400 lb springs lower a 250 with 5200 lb?
Sent from my SM-G955U using Tapatalk
rosspulliam
DFW
I just went out and measured mine for ****s and giggles.
6'2" to the peak at the center of the roof! I can drive into my 7' garage before the door is fully up and not even twang the antenna LOL
Jomax
Arizona
You have a 2wd?
kcpanages
Sorry for the derail, but I've watched a bunch of the truck videos from this youtube channel. The 99 F350 regular cab, shortbed dually with the 15 conversion is badass.
YES IT IS! Them guys out there got it going on
