Go Back   PowerStrokeArmy > The Bunker > General Discussion Forum
Reply
Thread Tools Display Modes
  #1
Old 10-12-2020, 05:51 PM
jmorty33 jmorty33 is offline
Private
Member's Gallery
Default Who is responsible when ....
Took my 2013 F350 in to replace a cracked cylinder head. Had all the symptoms and I knew that's what was wrong. Mechanic agreed. We decided to replace both heads .. new ones, not rebuilds. After completing the repair the shop drove the truck around for two days to make sure all was good. On day 2 during their test drive engine throws a piston rod punching a hole in the block. Who is responsible for the cost of new block and labor to fix it?
  #2
Old 10-12-2020, 05:52 PM
sootie's Avatar
sootie sootie is offline
General
Member's Gallery
Default
Depends what caused the failure. How were you so sure it had a cracked head to begin with? Not a common issue by any means...
  #3
Old 10-12-2020, 07:29 PM
Private
Member's Gallery
Default
Coolant was getting into the exhaust. I could smell it. White exhaust smoke at startup that would clear after a minute or two. Check engine code "cylinder 7 balancing issue. Mechanic said that the engine ran well right until it threw the rod
  #4
Old 10-13-2020, 05:23 AM
sootie's Avatar
General
Member's Gallery
Default
Which rod did it throw, #7?
  #5
Old 10-13-2020, 07:10 AM
Arisley's Avatar
Arisley Arisley is offline
Mod Squad
Member's Gallery
Default
Sounds like poor diagnosis to me.
__________________
E99 ECLB Dually, 2010 bed, 2005 headlights, smoked clearance lights, 2001 cup holder.
365,XXX miles. Pure stock, sorta.
SDRCM #478
PSA Conspirator # 22
  #6
Old 10-13-2020, 08:55 AM
79jasper's Avatar
79jasper 79jasper is offline
Colonel
Member's Gallery
Default
Quote:
Agreed.
Doesn't mention if the truck was on a diet, but a leaking egr cooler could have been the cause of both problems.
Sent from my SM-N960U using Tapatalk
__________________
2003 F250 KR SCSB FX4
Depleted, studded, airdog (which isn't currently hooked up), fass regulated return, airaide, 4 inch straight pipe with mbrp muffler(so on to go), glowchit pyro, fuel, boost, and trans temp. (Of course don't work lol) Hercules terra track A/T2 315/70/17.
2013 Honda pilot Touring
http://badges.fuelly.com/images/sig-us/778639.png
http://badges.fuelly.com/images/sig-us/776628.png
  #7
Old 10-13-2020, 11:18 AM
sootie's Avatar
General
Member's Gallery
Default
Quote:
Originally Posted by 79jasper View Post
Agreed.
exactly.
  #8
Old 10-13-2020, 04:30 PM
Private
Member's Gallery
Default
EGR was ******d 3 years ago. Mechanic says it threw rod #7. I haven't seen the engine yet. They are taking it out right now. I have several friends and acquaintances who either own car dealerships or repair shops and they all without hesitation said that it is the shop's responsibility... that's why they carry "garage keepers" insurance with "error and omission" coverage.
  #9
Old 10-13-2020, 06:04 PM
CTC DEEZUL's Avatar
CTC DEEZUL CTC DEEZUL is offline
General
Member's Gallery
Default
Lmao
__________________
Teamsters Local 444- Rolling Coal United
  #10
Old 10-14-2020, 06:59 AM
ToMang07's Avatar
ToMang07 ToMang07 is offline
General
Member's Gallery
Default
Sounds like you incorrectly self-diagnosed and don't want to pay for your error.
Sucks... but I can't see how this is the the shops fault. If they installed the heads incorrectly sure. But sounds like your motor was already fukked.
Sent from my SM-G960U using Tapatalk
__________________
~Tom~ 02 F350 CCSB 4x4 SRW 7.3L, DIY-6637, Hydra, 4" TB-409SS MBRP, GS 3 in 1, EGT/Boost/Tranny, T500, FRx, COMP 910s, Fisher 8' MM2, 5" AL 1-piece Drive Shaft, Tymar HPX, NON-EBV Pedestal, Turbo Master, Wicked Wheel, Hutch/Harpoon, RR-Plenums/clamps, 203* TS and Billet Housing, ELC, Fumoto, Leveled, Airlift Bags, 16x10" on 35s, CCV Dumped, Foil, AIH, and EBV, Pontoons All Missing... Rebuilt Transmission at 137k~AE w/Ford Pack~
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
