#1
I have a 02 7.3 has new camshaft sensor new idm new injectors.... You'll be drive down the road an it will like cut out but jerk ur head off an throw a puff of white smoke out then take off fine an then next time it might just shut off... So u turn the key off an bk on an it's fine again.. Might do it today an might not.. Plz tell me what the hell is wrong... Thank you!!
__________________
2002 f250...Dyno Proven custom tunes,Adrenaline Hpop,ARP headstuds,RiffRaff hpop lines,RiffRaff ebpv pigtail, 250/100% rosewoods,sinister regulated fuel return,fuel bowel ******,WW2,welded waste gate,bellowed up pipes,CCV mod,walbro fuel pump,6in exhaust,custom intake an kennys dual disk pulling clutch,16x12 mickey thompson wheels,cowl hood,isspro EV2 gauges.. ![]() |
#2
What color CPS do you have now? When was it replaced?
#3
Cps is almost exactly ur problem. Mine did same thing.
Sent from my DROIDX using Tapatalk 2 |
#4
Ford just done it Tuesday after buying them for yrs I used my factory recall replacement this time an let them do it
__________________
#5
An when it's wet an raining out it's way way worse... Thanks for all the help.. It's Pissn me off tho it bout jerks ur head off..
__________________
#6
Your windshield is most likely leaking might want to get it fixed
__________________
1999 F-350 CC SB Stock for now.. |
#7
Its not that old had it put in about 2yrs ago
__________________
#8
They were know to leak and take out your pcm
__________________
Thread Tools | |
Display Modes | |
