What's better than 1 turbo?
BlueWaffle
Grapevine, TX
yep....you guessed it. HUGE thanks to Matt at Cutting Edge Diesel for getting everything put together and built. Stoked to head up to the ranch this week to do some building! you better have that hay wagon gassed up cause I'm driving that b itch
anyways...as spin off from my compound sizing thread, this will be my "build" thread. I'll be running a BW 63/68/.83 t4 divided over a BEP 80/96/1.32. Injectors are staying the same for the time being. they're technically Casserly 190/100's but were flowed at around 200cc when they came off the bench. they're a few years old now so who knows what they're flowing but they still fuel hard. anyways, I'll have matt tinker with those later. we'll be running an external 46 mm gate also. to hold the new found powa, we'll also be putting in a built unit from Warren Diesel. Billet input and billet triple disk TC with new HD steels/clutches, etc. I'm driving up to his shop this Wed so we'll be slapping it all together into next weekend. We'll have lots of pics as we go and go pro vids as well.
Mpoage
OKC, OK
Are you gonna be coming back through OKC Sunday evening? I'd like to check it out.
faster6.0
sweet Sir lance-o-lot, I like the cajones. I wanna see a dirty burnout vid lighting those hair dryers to 70 psi.
TooMuch03
West Bend, WI
Looks quite nice! I bet that thing will haul.
I do have a question. I notice that the wastegate is connected to the passenger side of the divided up-pipes. Do you think there will be a differential in the drive pressures between the two banks of the engine once the wastegate opens becuase one of the up-pipes is gated an the other one is not?
kevin
springdale wa
Good question ... I was told if your running factory style up pipes its fine, but divided up pipes not so much
BlueWaffle
Grapevine, TX
that is a good question. I wonder if in this case it would be better to vent to atmosphere? someone a lot smarter than me is going to have to answer that one.
