Tom S
- Joined
- May 20, 2011
- Messages
- 3,365
- Reaction score
- 1
I got this in a PM but will answer it here to benefit all and generate some discussion.
The fittings on the back of the heads are 1/8" NPT or pipe thread at the head. I switched to -4AN hydraulic at that point. I did so as I did not have the intention of going large with injectors.
I do not think hardlines are a necessity. I enjoy making things and did so in part for that reason. I do like the idea of hard lines around the heat of the turbocharger.
Adding a fuse and relay to the factory fuse box takes some doing. The way to do this is the get a junk fuse box from the wrecking yard. That will supply the parts for the conversion and it will let you practice getting one apart damage free. Once you have one apart you will see how to tap power off the buss bar inside and you will have the parts needed to fill in a blank spot on yours. I got my parts from an old crown vic police car.
Looks like I'll probably be doing this soon as I have a fuel leak in the valley on my new to me 97. Couple questions for you if you don't mind...
Do you happen to recall the size of the fittings on the back of the heads?
Do you see any good reason why hard lines would be needed for feeding the rear of the head, or could a new line be made from braided SS fuel line?
You wouldn't happen to have the parts needed for adding a fuse/relay to the factory fuse box would you?
Any tips/advice you may have for doing this would also be greatly appreciated
