H&S dash pod for edge insight cts??
Sterling6.7
The dash changed in '13. The H&S version works great for me. You will need to buy the CTS pod adapter, then do a little cutting and epoxy the adapter on in the right spot.
It's a little spendy and the paint job sorta sucks but it works really well.
Jassman
MS
that looks good..curious if it would work with my Livewire some how.
I looked at it closer with my glasses..I see what you mean..I wonder if you can get that silver factory color
Sterling6.7
The silver is pretty close, the quality of the job is a bit miserable. I have tried in the past with crappy luck, but if I could find the exact right color, I would repaint it myself. It isn't horrible, but one of those things that a guy knows that he can do better.
Ctsvnino
North jersey
That looks good I can make it work
Arconalloy
Warner Robins, GA
So just pick up an h&s dash mount and the edge adapter? That's the same route I want to go when I order my edge. I don't want to just use the suction mount and I don't really care for mounting it near my rear view or down low by my cup holders or anything it seems like with it being right there close to the gauge cluster it would be in an easy field of view rather than further away from the cluster
Jassman
MS
Couple of bucks and that suction cup is gone
That looks great..nice and clean, and speaker is still exposed..how did you mount that to the backside..and is it possible to make those for a Livewire...for a fee. thanks Jeff
Sterling6.7
I have seen the adapter and it is pretty cheeseball. Waste of $20. I was going to use it in the dash pod, but it spaces the CTS out a bit too far. It is very adjustable though. I did like that.
