Go Back   PowerStrokeArmy > Power Strokes > 7.3 Tech
Reply
Thread Tools Display Modes
  #1
Old 10-10-2018, 07:25 PM
Rodslinger's Avatar
Rodslinger Rodslinger is offline
Lieutenant
Member's Gallery
Default Y2K dies after hi idle or high rpm
Trying to find out why my 2000 7.3 excursion dies. It just drops off from idle and dies. No miss. Tack follows the rpms down to 0 after it dies. Slight romp at idle. Icp running from 560/620 psi at 9- 14%. Fuel pressure is steady at 65 psi. If you are coming from any rpm higher than 1500 or so and just let off the throttle, it will idle down and die.
The injectors are rosewood 238/100 that are less than 2k miles. New undercover harnesses.
Anyone have an issue like this?
__________________
2000 Ford 7.3 4x4 Diesel Excursion. ******** tooning, TRI turbo, Jon Wood stage 2 trans, Custom PPG Waterborn Paint, Nitto 33" Trail Grapplers, Autometer gauges, 4"downpipe, 05 Harly Davidson lights, Custom billet grille, Sony DVD, Alpine Amps, other junk.
1995 Ford 7.3 F250 4x4 Super Cab. Power Hungry Preformance tooned, Rosewood Diesel stage 1 injectors, 6.Oh intercooler, Custom PPG Paint, 37" Toyo M/T, Sir Michels rollpan, Mickey Thompson 17" custom rims, and more.
  #2
Old 10-10-2018, 08:47 PM
Derik_C's Avatar
Derik_C Derik_C is offline
Private
Member's Gallery
Default
Crank shaft sensor
Sent from my SM-G965U using Tapatalk
  #3
Old 10-10-2018, 09:13 PM
Rodslinger's Avatar
Lieutenant
Member's Gallery
Default
Quote:
Originally Posted by Derik_C View Post
Crank shaft sensor
Iíve replaced it twice with the ford gray one. No change And itís not random like a CPS Almost every time it will do it by bringing up the rpms and letting off.
__________________
  #4
Old 10-10-2018, 09:58 PM
6.0 Tech's Avatar
6.0 Tech 6.0 Tech is offline
Colonel
Member's Gallery
Default
Full of oil? Do it with the icp unplugged? Nut on the ipr tight?
Sent from my VS988 using Tapatalk
__________________
04 cclb IDP and TSD tunes, KC Stage 2 hi pressure, S476 atmosphere, Odawg Stage 2 ported intake, RCD Stage 1 cam, RCD lifters and pushrods, RCD 120# valve springs, ARP 625s, o ringed heads, Warren 7mm 250/100 hybrids, Strictly bowl dereete regulated return, Air Dog 2 4g, Snow stage 2 water/meth
  #5
Old 10-11-2018, 10:22 AM
Rodslinger's Avatar
Lieutenant
Member's Gallery
Default
Full of fresh valvoline 15/40. New ford IPR and nut is tight. Have not tried unplugging the icp. Will do that today and report back.
Thanks.
__________________
  #6
Old 10-11-2018, 06:51 PM
lincolnlocker's Avatar
lincolnlocker lincolnlocker is offline
General
Member's Gallery
Default
Seems like my dually did this once a while back... gotta think
live life full throttle
__________________
00,f350,4x4,cc,drw, under the knife
01 rclb zf6,4x4,srw,ts tunes,bfaf,4"exhaust, 3800lb dd clutch
12,f350,4x4,cclb,srw, rudys/punch it d3lete tunes, donaldson bfaf.
  #7
Old 10-11-2018, 08:39 PM
Magnum PD's Avatar
Magnum PD Magnum PD is offline
General
Member's Gallery
Default
Don’t think it’s the chip. Might have something to do with pedal sensor.
__________________
96 F-350 RC 4x4 Hypermax Rods, PIS 300/200s G head tunes, Garrett GT4294, Beans IDM, ARP head & main, girdle, half filled block, DI cam, Dual IPRs, ceramic coated bowls, anti-friction skirts, Haldex pump over Honey Badger Jr, Diesel site High volume lpop, Billet intake Plenums, Dual SD pumps, Fluidampner, beehive springs, cosmetic head gaskets, Inconel valves, hardend guides, Ported and polished heads by me, home made RR fuel, 5 speed tranny, with SB 3600 DxD. Snow water meth.
  #8
Old 10-12-2018, 08:34 AM
Rodslinger's Avatar
Lieutenant
Member's Gallery
Default
Ok. After running it yesterday with the Icp unplugged, it has not done it yet. Iím going to run it some more tomorrow and see if I can make it die.
Now, if this solves the issue, what is it pointing to? Icp sensor? Or Hpop?
__________________
  #9
Old 10-12-2018, 10:47 AM
dsberman94's Avatar
dsberman94 dsberman94 is offline
General
Member's Gallery
Default
Icp
__________________
02 F250 7.3 Crew Cab Short Bed Lariat
PHP Hydra, Ge4rhead tunes, Edge insight CTS monitor
Mild Trans Build, Dual disc TC
GTP38R, T500, PIS 175/80s in the engine. waiting to see rods one day
Turned 200k miles 1/18/2015
  #10
Old 10-13-2018, 09:32 PM
Rodslinger's Avatar
Lieutenant
Member's Gallery
Default
So the truck will not die with the icp unplugged. Once itís plugged back in, it will die. Will be replacing the sensor tomorrow.
Thanks for the help guys.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
