Go Back   PowerStrokeArmy > Power Strokes > 7.3 Aftermarket
Reply
Thread Tools Display Modes
  #1
Old 10-09-2018, 04:22 PM
dmd's Avatar
dmd dmd is offline
Lieutenant
Member's Gallery
Default :looking for excellent mechanic in Lewisville Tx area
I think I have a cracked injector, lite white smoke at idle, happened between one stop light to the next. No intake noise, no exhaust noise, no puffing from oil filler. Will puff out a small white cloud out the exhaust accelerating from a stop light. Runs well other than when idling for a little while one cylinder seems a little weak and over fueled, once off idle it runs just as before with maybe a little more smoke at lower RPM.
I parked it and haven't driven it since it happened last week so no more damage can happen.
I have an appoint to get it in a few weeks out for a very trusted mechanic but wonder if there are some others in the area that can get it in sooner.
__________________
2k, F350 SuperCruzer, 7.3L Diesel, Auto trans, 4x4, GH Tunes w/160/30s, S&B cold air intake, 4-inch turbo-back exhaust, Garrett 38r, Adrenaline HPOP, BTS Transmission w/6.0 cooler, Swamps IDM(broke, back to stock), AIC, in-tank and pre-pump mod, Heater valve mod, X-car sound panel mod
  #2
Old 10-09-2018, 06:29 PM
ghohouston's Avatar
ghohouston ghohouston is offline
Colonel
Member's Gallery
Default
I pm'ed you
__________________
1997 F350 SRW CCLB 4x4 ZF5 7.3
2011 International Duraturd 4300 Mechanics truck
2001Tdi Jetta 5 speed
  #3
Old 10-09-2018, 11:07 PM
Strokersace's Avatar
Strokersace Strokersace is offline
Colonel
Member's Gallery
Default
Quote:
Originally Posted by ghohouston View Post
I pm'ed you
I was going to post about you.
Thatís basically your backyard!!
__________________
I'm sweatin' like a wh*re in church here!
  #4
Old 10-10-2018, 09:42 AM
dmd's Avatar
dmd dmd is offline
Lieutenant
Member's Gallery
Default
Thx.. We are getting together to see what is going on.
Hope to get it going again soon.
__________________
  #5
Old 10-10-2018, 09:13 PM
dmd's Avatar
dmd dmd is offline
Lieutenant
Member's Gallery
Default
ghohouston agrees that it appears to be an injector. Lite white smoke that burns your eyes. Found the ICP connector
with oil in it too.. Those ICPs sure are expensive. The harnesses ohm out good they are only 18-mos old so they better.
Box will arrive tomorrow from Unlimited Diesel so I can send the injectors back protected.
Going to get all 8 checked.
__________________
  #6
Old 10-18-2018, 12:26 PM
dmd's Avatar
dmd dmd is offline
Lieutenant
Member's Gallery
Default
Unlimited Diesel Performance found a leaking nozzle in one injector, covered it under
warranty and one day turn around. Appreciate their their customer service, always
answered the phone and answered any questions.
Truck should be back on the road in a few days, dependent on UPS.
__________________
  #7
Old 10-19-2018, 08:59 PM
taterthedog's Avatar
taterthedog taterthedog is offline
Major
Member's Gallery
Default
Good to hear.
  #8
Old 10-24-2018, 10:55 AM
dmd's Avatar
dmd dmd is offline
Lieutenant
Member's Gallery
Default
Truck is back on the road. ghohouston got it running last night with some very large clouds of smoke. Completely fogged the road when we pulled out of the drive.
Still purging the air from the lines, but better after a drive this morning. Was like
starting a 6.0 with HPOP leak for awhile, took about 3 seconds to start. Now maybe
a second. Should get back to just a quick crank soon I hope. Idle is back to normal
though.
We are pretty sure the IPC was the original one, should help with the new one. They
sure are expensive.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
Designed by Military Ltd
