6.7 Wastegate kits
Athens, IL
As some of you who have followed the test mule thread, we have been running a wastegate kit on a few of our trucks for about a year. Some other companies have came out with wastegate kits in the mean time. We finally settled on a design that will work with virtually any setup. So better late than never!
It utilizes the factory egr port and comes with stubbed tubing to weld into you stock or aftermarket down pipe. The kits were originally using a 38mm gate but we have switched to tial mvr 44mm for guys who want to spray a lot. They will come with regulator, hose and fittings.
We are marketing them at $895 should be a nice addition for people running smaller turbos with added fuel or anyone who plans on using nitrous.
Stainless piping made in the USA and in stock!!
Some pictures of the finished product and a few of the prototypes on engines
CWAY6.7
Morgan, not sure but I would assume this would work with the H&S kit? Or a retro 15 kit? and Ill be using a 15hpfp since I have dual alternators.
jcain
It'll work with any kit that uses stock manifolds.
It won't work with the h&s. H&s has a provision built into the driver manifold.
Athens, IL
Jon is right. It will work with stock exhaust manifolds with egr provision. I have one on my 6.7 with a 2015 turbo. Sprayed 420hp worth of nitrous through it and kept all the pressures in pretty good check respectively.
Notneb
Does this bring back the 6.7 scream of the 11-14's or was that strictly a twin scroll phenomenon?
