DPC 2016
jester2011
Good luck to the fords who made it into DPC 2016 voting. I never thought o would even come.
Kbuterbaugh04
Congratulations. From what I've seen you'll be in some good company.
Sent from my SAMSUNG-SM-G870A using Tapatalk
ckrueg
Belding MI
I was curious about that. Is 1000 hp doable with all the junk still on?
I wonder if you could if you made dual exhausts with a *** in each. Twice the flow. And you would probably need a setup with lots of air flow to keep the smoke to a minimum
jester2011
As far as I know the emission rules are not in effect yet.
jester2011
It will make a, 1000hp bit at elevation things change lol
Shelbyville TN
You must have gobs of hr's of tuning to get a *** to live at 1000hp?? Most DOC's and ***'s crack at around 1300 degrees, anything over 1500 degrees is meltdown inside the DOC before it reaches the ***s.. I'd be extremely impressed to say the least if I saw the trucks perform a parked regen then lay down 1000hp on a chassis dyno no doubt.
jester2011
The emissions rules are not in effect this year
