Go Back   PowerStrokeArmy > Power Strokes > 7.3 Aftermarket
Reply
Thread Tools Display Modes
  #1
Old 02-14-2018, 05:25 AM
C'roy78stroker C'roy78stroker is offline
Sergeant
Member's Gallery
Default Let's spitball... 7.3 with shorter stroke?
Just something that came across my mind. I was try to think of a negative to this hypothetical scenario. The ones I could think of would be a drop in torque, added expense for a longer rod, or block deck machining depending on the amount of de-stroking. What drew me this direction was if we had a smaller displacement engine but fed it the same fuel, for sake of max effort, 400/400's and then also ported the cylinder heads... Would the HP numbers go up any higher? Or would we still be breaking even do to fuel and air remaining constant? Just a thought, but I'd like to hear some speculation.
__________________
1997 Eclb 4x4 auto
05 axles Gen 3
  #2
Old 02-14-2018, 07:09 AM
ja_cain's Avatar
ja_cain ja_cain is offline
Colonel
Member's Gallery
Default
Quote:
HP is a function of torque/RPM. I would think that unless you are getting significantly more RPM out of it, then you are taking a step backwards. I could be wrong in my assumption, but I feel like the RPM is limited more by how fast the injectors can operate than the stroke on the 7.3. Destroking it could improve rod to stroke ratio which would increase the longevity of the rods and less stress on the block too.
  #3
Old 02-14-2018, 08:22 AM
Petro's Avatar
Petro Petro is offline
Major
Member's Gallery
Default
If less cubic inch was what you were after, I would think sleeving down the size of the cylinders would be a simpler way to go about it. I'm very curious to see where this discussion goes. Seems like I remember Morgan saying something about removing cubic inch from a 7.3 in a discussion a few years back. It was all hypothetical but I thought I remembered this conversation happening on here. Good topic by the way.
__________________
Tow Rig/ Daily Driver
06 F350 CCSB 4x4 6.Blow ZF6, 220k - Warren Tuned, 190/100's, Powermax, RR, Ported Manifold, Fass 200, Water/Meth
Pulling Truck
05 F250 CCSB 4x4 6.Blow 5r110, 230k - Hybrid 250/100's, S369, RR, Fass
Past: Several 7.3s and a few 6.4's
  #4
Old 02-14-2018, 10:54 AM
ja_cain's Avatar
Colonel
Member's Gallery
Default
Quote:
I vaguely remember that discussion too. Sleeving down should strengthen the block due to thicker cylinder walls. Rotating assembly would be lighter too due to smaller/lighter slugs.
  #5
Old 02-14-2018, 11:44 AM
morefuel's Avatar
morefuel morefuel is offline
Sergeant
Member's Gallery
Default
From what i remember somebody, Morgan or HotRodTractor I believe, said the best from a performance aspect would be a large bore and short stroke. The big bore allows for a larger valve area to get the most air in. I believe it was in a discussion on stroker kits for 6.4's and that for strictly adding cubic in. that adding bore was more effective than stroke because of headflow/valve area.
And I think that the 7.3's main issue is the injectors aren't fast enough for high rpm so to make horsepower they are forced to make gobs of torque.
I'd be curious to know if block weakness is more relative to cylinder pressure or from actual engine torque.
__________________
97 f?50, ZF-5 tranny, 6637, 3" downpipe 5" exhaust, PHP six position, 6.0 liter I/C, Polished 304 stainless I/C tubing, DIY exhaust brake, 2005 axle swap with 3.73, 280HP 551 ft. lbs as of May 2011. 2008 f250 6.4
  #6
Old 02-14-2018, 03:32 PM
ja_cain's Avatar
Colonel
Member's Gallery
Default
Increases in cylinder pressures will most likely track increases in torque or vise versa.
Good point about a large overbore and the ability to run larger valves. 7.3 could probably benefit from this, but not sure how it's open area scales from say a 6.0 or 6.4.
  #7
Old 02-14-2018, 05:16 PM
superpsd's Avatar
superpsd superpsd is offline
Major
Member's Gallery
Default
How about a Big bore short stroke engine with commonrail kit. Sounds expensive.
__________________
97-250 7.3 Eaton TVS Supercharged, S369sxe, R&D IDI performance T4 mount, my B350/200s, Honey Badger SR with My tunes, BMW M3 seats, Sky 5" RSK skyjacker drop pivot brackets, Sky shackles and hangers, Toyo M/T
1948 GMC Detroit 453T
1951 Mack A51T
1916 Federal 1 1/2T
  #8
Old 02-14-2018, 05:40 PM
psduser1's Avatar
psduser1 psduser1 is offline
Colonel
Member's Gallery
Default
Sounds fun!
__________________
2000 f250 zf6, air, oil, fuel mods, flatbed dual dana 80
Almost stock
2001 f250 same setup as the 2000, auto trans
2002 with a couple of mods, grocerygetter
  #9
Old 02-14-2018, 05:55 PM
JDelaney JDelaney is offline
Sergeant
Member's Gallery
Default
Probably be cheaper to punch out a 6.7L to 7.3L.
__________________
Late 99' CC, LB, 4x4, Unlimited 238/100, G3arh3ad Tunes, Irate T4 mount, BW364.5SXE, 6.0L intercooler, Transgo shift kit, billet 3 disk converter, 3.73 gears, 2010 Dana 80, 2008 Dana 60 front end conversion
  #10
Old 02-14-2018, 06:10 PM
Petro's Avatar
Major
Member's Gallery
Default
I believe the discussion on removing cubic inch was strictly to deal with the limitations of heui injection system like the OP suggested. Basically making the most of the fuel the 7.3 is able to inject in the given window. With a common rail Injection system, I don't see any reason to eliminate cubic inch when you would have basically unlimited amounts of fuel flow. Head flow would be the biggest limitation after that. That's the way I see it, but I could be wrong.
__________________
Pulling Truck
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
