Go Back   PowerStrokeArmy > Power Strokes > 7.3 Aftermarket
Reply
Thread Tools Display Modes
  #1
Old 02-14-2018, 04:05 PM
Brian Taylor OBS Brian Taylor OBS is offline
Private
Member's Gallery
Default Question for the regulated return guys?
Hey so I have been running regulated return for a year on my 96 7.3. Baby Swamp injectors, ts, kc turbo, and intercooler. I just towed heavy down to king of the hammers from Oregon(17k). I noticed as my tank got below half my egt would climb to like 1050 flat land od 65 ish mph. I switched to my second tank and saw my egts drop by like 75 to 100 degrees. I thought it was a fluke but after 1500 Miles. I decided itís a thing. I felt my fuel filters at like a 1/4 tank at the gas station. To the hand I would estimate 100-110 degrees. Ball park. After fuel up they drop to 60 ish or whatever the diesel from the tank was. I could only tell when pulling on flat ground. The hills cause too much variation in egts anyway.
Has anyone experienced this before. Never noticed with the truck empty. I makes sense to me that at some point hot fuel equals slightly hotter egts samec as intake air.
__________________
1996 F350 CCLB, 244K, Baby swamps, Irate E Fuel, built E4OD, 35's, TS-6 from Swamps
  #2
Old 02-14-2018, 07:14 PM
mcnance865 mcnance865 is offline
Private
Member's Gallery
Default
I am certainly not an expert, but could have something to do with the warmer fuel going back to the tank and as the total volume of fuel decreases, that extra bit of heat from the return fuel is increasingly a higher percentage of total volume of fuel. What I am saying is; as the amount of fuel decreases, there is less volume to soak up the extra heat so to speak. Hope this makes sense what I am trying to say. I'm not sure this would really make that much of a difference though.
__________________
2000 F-250 4x4 SuperCab Short Bed 7.3 w/ 280,xxx mi - 4" Pro Comp - Redhead - 37x12.50x17 BFG A/T KO - 3.73 Gears - CTS2 - Hydra - FFD 238cc/80%
KC38r 366 - Adrenaline - Irate Fuel System w/ Sump - 4"Exhaust - K&N CAI w/ S&B Filter - FFD Bellowed Up Pipes - AIH Plug - RiffRaff Plenums & Boot Kit
  #3
Old 02-17-2018, 02:31 PM
Private
Member's Gallery
Default
Yeah I didn’t think it would make much difference either. One reason I thought there might be something to it is I know the 6.4 has a fuel cooler. Honestly I drove it for a year and never noticed. It was only towing heavy on perfectly flat ground with less then half of a 15 gallon tank. Just curious if anyone else has noticed this before.
__________________
  #4
Old 02-18-2018, 06:04 AM
farm boy's Avatar
farm boy farm boy is offline
Sergeant
Member's Gallery
Default
I run a fuel cooler I bought off ebay on the return line on my 7.3. Seemed to help as far as the temp at the filters that you described. Maybe worth a try.
__________________
~2013 F-350 6.7L Dually 4X4
~2003 Peterbilt 330
~2002 F-250 7.3L 4X4 Flatbed
~2014 Toyota Tacoma 4X4
~2004 F-350 Shorty 6.0 2wd (SOLD)
  #5
Old 02-18-2018, 03:46 PM
Northwest444 Northwest444 is offline
Private
Member's Gallery
Default
I have a regulated system from dieselsite and has a fuel cooler on the return, and never have experienced this issue. I would imangine it helps keep the fuel at a more constant temp.
__________________
99 350 t-4 mount,borgworner S369, full force 250s studs. and abunch of other things.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
Designed by Military Ltd
