Go Back   PowerStrokeArmy > Power Strokes > 6.0 Aftermarket
Reply
Thread Tools Display Modes
  #11
Old 04-27-2018, 10:13 AM
strokin6L's Avatar
strokin6L strokin6L is offline
Colonel
Member's Gallery
Default
Quote:
Originally Posted by morefuel View Post
I'm surprised nobody suggested stock. I've read on this forum that it'll flow for around 500 hp. Maybe you're above that.
Wrong, stock intake will not flow enough air to sufficiently support 500hp. The 500hp thing is nothing more than a myth. Stock is good to about 425hp...past that it just can't supply enough air that the turbo demands(especially a larger one) and becomes restrictive. If anyone has ever paid any attention to the filter minder that these trucks are equipped with...you'd notice this. Another reason why some intake brands that have the enclosed box style will suck the filter minder in because the turbo is demanding more air than the filter can actually flow
__________________
2004 F-350 SC FX4, Dakota Digital gauges, insight CS, SCT, tuned FICM(ID), AFE, spearco intercooler, water injection, FASS, Fuelab, Hellmann's sump, regulated return, .020 over motor, RCD stage 2 billet cam, UCF O-ringed heads, ARP's, 120# springs, chromoly pushrods, Casserly 190/75, KC billet stage 2 vgt turbo, BD exhaust manifolds, stage 3 ported manifold, amsoil oil by-pass, suncoast trans w/billet input
  #12
Old 04-27-2018, 01:19 PM
SICKS LITER SICKS LITER is offline
Sergeant
Member's Gallery
Default
Ive gone 12.7 @ 105 with 155s and a pmax running the stock air box. Didnt suck the filter minder in either
__________________
2006 Black XLT Sport F350 SCSB 4x4 - 03 Motor, EGR Gone, ARP Studs, New Ford Heads & Gaskets, Pmax, Xtreme Race, Diesel Site Coolant Filter, PHP 80hp FICM, Flo Pro 4", CTS2 w/Fuel PSI & Pyro, Detroit Truetrac
  #13
Old 04-27-2018, 03:10 PM
strokin6L's Avatar
Colonel
Member's Gallery
Default
I've seen numerous trucks with just exhaust and race tune suck the filter minder in at least half way stock airbox and new oem filter. I've also seen trucks with same mods suck it in all the way with the addition of a powermax. There was an instance that I had a truck never suck it in do to a faulty/sticking filter minder
__________________
  #14
Old 04-27-2018, 04:20 PM
Sergeant
Member's Gallery
Default
Ive had multiple aftermarket intakes suck it in more than a stock filter. A nice little trick with the stock set up is to gut a stock filter out for track use. Point is if it was a major restriction i doubt i would have run 12.7 with 155s or run 13.2 with stock sticks.
__________________
  #15
Old 04-28-2018, 07:23 AM
mstng5point0 mstng5point0 is offline
Sergeant
Member's Gallery
Default
My truck with the Kc stage 2 would suck the filter minder in if i laid into it for a few gears. I bought the one in the link i posted a few weeks ago. Egt's seem a little lower and spool up is quicker. I'm happy.
__________________
2007 Harley F250 tuned, ******d, studded, straight piped
  #16
Old 04-28-2018, 07:49 AM
morefuel's Avatar
morefuel morefuel is offline
Sergeant
Member's Gallery
Default
If it's like the 6.4 the filter isn't the real restriction, it's the snorkle.
__________________
97 f?50, ZF-5 tranny, 6637, 3" downpipe 5" exhaust, PHP six position, 6.0 liter I/C, Polished 304 stainless I/C tubing, DIY exhaust brake, 2005 axle swap with 3.73, 280HP 551 ft. lbs as of May 2011. 2008 f250 6.4
  #17
Old 04-28-2018, 08:05 AM
strokin6L's Avatar
Colonel
Member's Gallery
Default
Lol...the filter is the restriction...no way around it.
__________________
  #18
Old 04-28-2018, 08:10 AM
strokin6L's Avatar
Colonel
Member's Gallery
Default
Quote:
Yes you can still make power and run those times with a stock intake, but that isn't my point. Hell, you can make over 600hp if you wanted with the OEM setup. But why would you want to restrict airflow when the turbo tends to demand more of it at levels about 425hp
__________________
  #19
Old 04-29-2018, 02:52 PM
Sergeant
Member's Gallery
Default
Just did a wot run 0 to 70 peaked 31.2psi of boost popped the hood when i got back and filter minder never moved. Not trying to create a pissing match, just saying
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
Designed by Military Ltd
