25% discount on ford parts to members
Countryboy07
N. Manchester, IN
hpop list $626.67 sell $517.00 no shipping charges
Thank you! I just thought of something else I need... The o-rings to go with the HPOP that need to be replaced, I already have the HPOP screen from when I had my '03. If I could get a package price, I'll place the order tomorrow or monday. Thank you!
-French
8upwitHDs
All parts for 2005 F350 SRW. I want to rebuild the front end.
upper ball joints x 2
lower ball joints x 2
Yellow o-rings x 2
Axel Dust Seal x 2
Wheel Seal x 2
lower ball joint snap ring x 2
Upper ball-joint nut x 2
lower ball-joint nut x 2
o-ring kit (includes 1 snap ring and two black hub seals) (5C3Z1K106AB) x 2
Cotter pins x 4
Studs to connect hub bearing to knuckle x 8
Nuts for above studs x 8
Hub Unit Bearing Assembly x 2
Inner tie rods x 2
Outer tie rods x 2
the ball joint that the trac bar connects to x 1
the drag link ball joint that connect to the pitman arm x 1
anything else that I might have missed?
Jim,
Did you forget about me??
Countryboy07
N. Manchester, IN
-French
Ready to place my order... Need a price for the rest of the parts please!
Thank you,
French
sunrisefordparts
-French
oring kit list $5.00 sell $3.75
Countryboy07
N. Manchester, IN
Can somebody check on my order status? I placed the order on monday and the guy I was talking to said he would call me back with a shipping number shortly... Never received a call... We are really needing these parts!
Name is Joshua French
Thank you!!!
sunrisefordparts
Thank you!!!
cant explain why a the phone call was mad but your part shipped out tracking # 1Z5775X90350144258
