Scratch and dent 6.0 compound special
Cutting-Edge Diesel
Newkirk, OK
I have a custom compound set up that was made for a twin pump kit. Customer returned it. There arnt any scratches and dents just the customer painted it. so instead of paying to have it sand blasted Im just going to sell it at a discounted rate.
Set up is made for a s400 high pressure and low pressure. JGS 50mm gate.
Its my Quick spool layout. Also includes a compound extras kit. The low pressure mount will be modified to be like my normal compound setup. I can also make it to work with a S300 turbo If you buy a JGS wg so I can mock it up.
this whole set up would run you $3850
I will sell it for $2800
this is the color the charge pipes are painted
here are pictures from when i was building it
