Soft Sidewall D-Rated/8ply 18" Tires?
lxcoupe
I'd like to stay around 33" in diameter, and my truck is a daily driver and won't likely tow anything more than a car trailer. I'd like to find the softest 8-ply/D rated/ 121 load index tire I can find and make my size choices after that.
275/70/18
285/70/18
305/65/18
Anyone have experience finding a soft sidewall all-terrain tire in 18" sizes? The 16" wheel 6.0 guys have been using D-rated tires for years, to help with ride quality.
gotchadollar
Personally opinion, the Nitto terra grappler G2 is by far the best riding and best quality tire I have found, I used to have Toyo at2 and I hated they way the truck rode, they are damn near the same tire it that nitto is by far hard to beat.
Zeb
Downtown Marrowbone Ky
BFG All terrain T/A
I second this.
Had a set of them in 285/75-16 on our Excursion. Got 75,412 miles out of them. Next was a set of Nitto Dune Grapplers in the same size, and they went 65,946 miles. It has Nitto S420’s on it now in 305/50-20, but that is shorter than you want.
So far the BFG All Terrains were the cheapest per mile of any tire I’ve ever run.
lxcoupe
I second this.
Cheapest per mile is actually not my concern, a soft sidewall is of primary importance. From my experience, the BFG All Terrains last so long because their sidewalls are so stiff! Would consider them if they offered a D rated version but they don't.
PDT1081
Bowling Green, OH
Every tire has a soft sidewall if you run low enough pressure.
I find them quite soft.
not necessarily
Yes and no. If you fill an E rated tire to 50psi it will still be stiffer than a D rated tire at 50psi.
For example: a BFG all terrain on the rear of my reg cab 350 will go down to the rim with 0 air pressure.
I currently have been running a toyo m/t for two weeks with 0 PSI IN THE TIRE and it is only a slightly larger bulge at the bottom than the other three.
Which reminds me...i need to fix that tomorrow lol
