Go Back   PowerStrokeArmy > Power Strokes > Aftermarket Super Duty 1999 - Current
Reply
Thread Tools Display Modes
  #7371
Old 03-23-2019, 07:02 AM
Tom@BigTimeKustomz's Avatar
Tom@BigTimeKustomz Tom@BigTimeKustomz is offline
Sponsor
Member's Gallery
Default
Looks great! Been contemplating getting mine done.
__________________
Big Time Kustomz Diesel and Off-Road Performance
2013 F350 CC/LB - Sterling Gray, Lariat Ultimate, 22X12 FF19's, Toyo Rubber, MPD 364.5 Turbo with Piping Kit, iPad Dash kit, Amp Steps, Bilstein Suspension
Contact me for great pricing on the industry's leading products tom@bigtimekustomz.com
  #7372
Old 03-23-2019, 10:11 AM
C2tuck's Avatar
C2tuck C2tuck is offline
Lieutenant
Member's Gallery
Default
Quote:
Thanks man. Iím not a fan of chrome. A little is ok, but that was always way too much. Wanted to Chrome my tow hooks, but didnít want to pull the bumper again to put them back on lol.
__________________
2015 CCSB F250 XLT FX4...American Force, Toyo AT 2ís, TSD tunes, EZ Lynk, 4Ē Flo Pro, Fox 2.0ís.
  #7373
Old 03-23-2019, 10:41 AM
lincolnlocker's Avatar
lincolnlocker lincolnlocker is offline
General
Member's Gallery
Default
Quote:
Originally Posted by C2tuck View Post
Finally got my bumpers back!! Powdercoater has to redo them because of contamination on the first run. Dude does phenomenal work! My painter wanted $600 for the bumpers alone, got them powdered for $245!!
Anyways hereís the before:
After:
Also added 2wd valence, switchbacks, and Baja design fogs. New emblems are being painted as we speak, hopefully have them next week.
Yeah, yeah I know...either gonna get morimito LEDís, or send them off to retro and get amber deleeete and HIDís...still undecided.
Iíll be doing the rear tomorrow.
That looks frickin great!!! I like it a lot!
__________________
00,f350,4x4,cc,drw. Sold... good bye ole girl. I will miss you
15,f350,4x4,cclb, not stock
  #7374
Old 03-23-2019, 12:17 PM
sootie's Avatar
sootie sootie is offline
General
Member's Gallery
Default
Wow that looks great. How good does the powder match the paint? And what did they do the center bars with?
  #7375
Old 03-23-2019, 02:50 PM
C2tuck's Avatar
Lieutenant
Member's Gallery
Default
Quote:
Itís pretty close. I never imagined there where that many shades of white. I picked the closest swatch of the 4 I had it narrowed down to, then got a few opinions and they all agreed. Honestly I think itís just a tad brighter than the truck, but Iíll probably be the only one that ever notices. It was called Dew White.
I ordered the black bars and Cís from Ford.
__________________
  #7376
Old 03-23-2019, 02:54 PM
sootie's Avatar
General
Member's Gallery
Default
What colour black bars
  #7377
Old 03-23-2019, 03:39 PM
C2tuck's Avatar
Lieutenant
Member's Gallery
Default
They are the textured black bars off an XL model I guess.
__________________
  #7378
Old 04-01-2019, 07:38 PM
6speedsd's Avatar
6speedsd 6speedsd is offline
Colonel
Member's Gallery
Default
Finally got with the program and swapped to a 6.4 starter on my 6.0.
Went to change the oil, and I have fuel in it. Son of a.....
About 2 qts worth in 5000 miles. Had about 16qts total when I drained the pan. You can smell it slightly, and itís thin thin. I pulled all 8 injectors a couple months ago and did a re seal on them since I had a couple inner seals blown out. Hoping I just damaged one of the lower O-rings on reassembly and itís not a cracked head. Truck still ran fine, but had a slight miss at times which makes me wonder if an injector is hanging slightly. I swear itís always something....
__________________
2005 F350 2wd CC DRW Lariat
Diamond Eye 5" straight piped
155/30's
KC Stage 1.5
WPE RR and Uppipes
  #7379
Old 04-01-2019, 08:05 PM
Zeb Zeb is offline
Lieutenant
Member's Gallery
Default
About 2 qts worth in 5000 miles. Had about 16qts total when I drained the pan. You can smell it slightly, and it’s thin thin. I pulled all 8 injectors a couple months ago and did a re seal on them since I had a couple inner seals blown out. Hoping I just damaged one of the lower O-rings on reassembly and it’s not a cracked head. Truck still ran fine, but had a slight miss at times which makes me wonder if an injector is hanging slightly. I swear it’s always something....
Where did your injectors come from, and how many miles on them?
Fuel in the oil is usually an internal oring that has gotten hard (because the builder used the incorrect type of oring) and is no longer sealing, not from the head being cracked. Cracked head is fuel in the coolant.
  #7380
Old 04-01-2019, 08:31 PM
6.0 Tech's Avatar
6.0 Tech 6.0 Tech is offline
Colonel
Member's Gallery
Default
Had quite a few that had cracked heads and dumping fuel in the oil... It depends on where the head cracks as to where the fuel dumps. I believe there is actually a tsb for it, along with the fuel in coolant, if I remember right.
Not to scare 6speed though..,
__________________
04 cclb IDP and TSD tunes, KC Stage 2 hi pressure, S476 atmosphere, Odawg Stage 2 ported intake, RCD Stage 1 cam, RCD lifters and pushrods, RCD 120# valve springs, ARP 625s, o ringed heads, Warren 7mm 250/100 hybrids, Strictly bowl dereete regulated return, Air Dog 2 4g, Snow stage 2 water/meth
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
Designed by Military Ltd
