Looking for customer input
ckrueg
Belding MI
Copied from the Facebook group.
"You will need to contact [email protected] with your name and tuner serial number. If you are not registered with us, you will need to get registered. If you purchase a SOTF switch/cable, you will need to contact us for the Level 2 license required to run the SOTF tunes. That license is included in the $200 pricing."
If you are on Facebook I would recommend joining the updates group as any updates made are posted there immediately.
compoundturbo373
uploaded the ost tuning on my truck current setup is mpd s472 sxe rcd cp3 kit rcd 100 over injectors elite fuel bowl ****** fass 150 all the correct settings where selected cp3 was ran unplugged but idle frp was 24 000 stock fuel system worked mint before the cab went up talked to other guys running the setup there sitting around 5k at idle but different tuning im thinking its a tuning issue can anyone chime in thanks
