Go Back   PowerStrokeArmy > Power Strokes > 7.3 Aftermarket
Reply
Thread Tools Display Modes
  #121
Old 10-11-2018, 09:08 AM
lincolnlocker's Avatar
lincolnlocker lincolnlocker is offline
General
Member's Gallery
Default
Quote:
Originally Posted by Dirtclod View Post
Ok here’s a another update. Yes I am running a wastegate. My ICP is bad and either my stock fuel pump is not going to big enough or it’s weak,according to the mechanic. Also I may not have programmed the hydra chip right so it might be running on stock computer. Or something isn’t right with the chip and just needs updated. Also there is a fuel leak off the return side under the truck. He sounds pretty optimistic that it’s a simple fix.
That was going ro be my first suggestion as to taking the line off the wastegate diaphragm and plug it and see what it does. Next step is tighten the gate adjustment rod.
I tried to run my dually with that red line plugged into the wastegate diaphragm and it made it spit and sputter and stumble.
Im not 100% sure but i think it is the pw that goes up with the lack of icp.. i could be backwards or way off cuz it has been since 2010 since i have needed anything that has to do with tuning. Thats when i but the bullet and drove down to beans and had it live tuned on the dyno..
Only issue still is that it is still drawing a lot of juice somewhere.. like a lot.. lol..
__________________
00,f350,4x4,cc,drw. Sold... good bye ole girl. I will miss you
15,f350,4x4,cclb, not stock
  #122
Old 10-11-2018, 10:22 AM
Dirtclod's Avatar
Dirtclod Dirtclod is offline
Lieutenant
Member's Gallery
Default
He did say he was not familiar with the hydra chip. Mostly what he’s dealt with is edge products. Which I suppose is ok. They’re probably better than they used to be and I guess that’s what they refer to as generic tunes. I sent him the info for him to call PHP and get whatever info he’s wanting. I’d say he’s going to get a little schooling. Maybe make him better at understanding these 7.3’s. Or at least tuning and whatnot. Far as pw and tuning and all that,I’ll leave it to the experts. I’m done working on these engines. Just basic stuff. It cost me twice as much to do it myself,lol!
  #123
Old 10-12-2018, 06:32 AM
Dirtclod's Avatar
Lieutenant
Member's Gallery
Default
Just a thought here,is it possible if when I cleaned the Silicon off the contacts on the pcm that maybe I took too much off of one or just a couple of contacts? Or maybe it’s close enough that it’s causing issues?
__________________
01 F-250 4x4 cc/sb 238/100 inj,adrenaline hpop,reg return fuel system,s&b intake,4” elec conduit straight back exhaust,KC stage 1 turbo,hd built auto tranny,pohp hydra chip custom tunes,still needs alot it’s work in progress.
  #124
Old 10-12-2018, 06:49 AM
DieselDC's Avatar
DieselDC DieselDC is offline
Sergeant
Member's Gallery
Default
Could be. Swamps will repair for you if you did. Take a picture and Let’s see what it looks like
—————signature—————
~Don’t overthink something simple~
...:uptight people suck:...
  #125
Old 10-12-2018, 06:51 AM
Dirtclod's Avatar
Lieutenant
Member's Gallery
Default
Quote:
—————signature—————
I’ll see if the mechanic will do that.
__________________
  #126
Old 10-12-2018, 05:54 PM
Dirtclod's Avatar
Lieutenant
Member's Gallery
Default
He says he’s not having a problem with communication just initial programming. ???? I don’t understand
__________________
  #127
Old 10-12-2018, 06:01 PM
DieselDC's Avatar
Sergeant
Member's Gallery
Default
He rounds like he don’t know what he’s talking about . Take off the hydra - your truck will run- just not optimum. This will see if hydra is causing the problem.
—————signature—————
  #128
Old 10-12-2018, 08:11 PM
Dirtclod's Avatar
Lieutenant
Member's Gallery
Default
—————signature—————
Lol! I should just go get it probably but I’ve got too much to do tomorrow. If by next Friday it’s not at least diagnosed for certain,I’m going to pick it up and take it to full throttle diesel in High Point NC. They’re probably a couple months behind but it’s really my only other choice. Let’s hope he has a handle on it.
__________________
  #129
Old 10-12-2018, 08:21 PM
DieselDC's Avatar
Sergeant
Member's Gallery
Default
Damn I wonder what he’s going to charge to take the truck back!!’
—————signature—————
  #130
Old 10-12-2018, 08:22 PM
Dirtclod's Avatar
Lieutenant
Member's Gallery
Default
Who knows?
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
Designed by Military Ltd
