ATS Turbo Wheel
DarkSide2.6
Maryland
I'm sure this is a lost cause but My brother is looking for a place to get a new wheel for the IDI ATS turbo. Anyone know where to get one or have a used one? Thanks, Chris
0 Xero 0
There's a gentleman by the name of Typ4 or Type4 on oilburners.net and ford-trucks.com. Get ahold of him He bought all the castings for these turbos and will be able to help you.
DarkSide2.6
Maryland
Thanks for the info 0 Xero 0. I ended up getting a bigger wheel, shaft and machining the housing to accept the bigger wheel. Good info for anyone else with the same problem though.
-Chris Cayer
Sent from my iPhone
Dieselsite
I know you fixed your issue, but we will have our Wicked Wheel 2's cut for these OE ATS turbos in a week or so.
Bob
RacinNdrummin
The restriction on the 093/Factory turbo is the Exhaust wheel, not the cold wheel. You can gate around it, but the stage 3 wheel is so small you lose all your shaft HP and it doesn't want to drive the cold wheel hard and deliver good boost numbers.
Are there any compressor maps for the wicked wheel? What is the weight of the WW in grams?
IDIoit
i bought my WW2 from conestoga diesel in PA.
190 bucks.
right now its at TYP4's place getting a new hot wheel and balanced with the WW2
OEM ATS 093
he also (like previously posted) has the updated up pipe castings!
he tells me that they are leak free!!!
my OEM up pipe config is a PITA. they leak no matter what i try!
this should complement my Bull Moose and Mister Mark II injectors nicely!
running a 1000 CFM FMIC also.
i have not read about anyone using the WW2, so ill post back after its done.
http://i109.photobucket.com/albums/n80/h0trod389/032_1.jpg
