STROKIN N STYLE
I forget who's truck this was but he said he was running 35's on stock lift.
Those are 20x9's on his truck at stock height. I ran the same setup for a while
Sent from the Sea
Do you think -24 is too much?
No I don't think so. You might have to pull the fender back a little. What size lift do you have?
Make sure if you level it you get a adjustable trac bar. Makes a huge difference. I just did mind yesterday.
I'll def put that into consideration!
Just what I needed. Thanks!
