Go Back   PowerStrokeArmy > Power Strokes > 7.3 Aftermarket
Reply
Thread Tools Display Modes
  #1
Old 11-14-2017, 04:55 PM
brandonmc07's Avatar
brandonmc07 brandonmc07 is offline
Corporal
Member's Gallery
Default What Fuel system to install with my mods? fass?
So I'm wondering if I should install a fuel system on my truck and if I even need one. How to I know which system to use as far a how much fuel they are pushing? Like a 90, 125, 200, or 225 GPH and they have different pressures. Then there are the driven diesel or irate systems built specifically for the 7.3.
I know I would have to add the fuel bowl ****** system to my current reg return system.
If someone could tell me the benefits of having a system vs staying with my the stock pump I would appreciate it. The main reason I started looking into it is because I noticed sediment in the fuel filter bowl when I change my filter last time. My injectors are 238/80 hybrids. I don't plan on adding anymore power in the near future do to having PMR's.
One more thing to add, Should I consider upgrading valve springs and pushrods?
__________________
7.3, afe intake, 5in mbrp exhaust, Gear.head tunes, Reg return, GTP38r, blank pedestal and outlet, 238/80s, BTS Trans w/ 6.0 cooler, HoneyBadger JR. HPOP, Mean Green Starter, RedHead steering gear, riff raff boots, International bellowed up-pipes, 4in lift, 20x12, 35x12.50's
  #2
Old 11-14-2017, 05:11 PM
sootie's Avatar
sootie sootie is offline
General
Member's Gallery
Default
Just do a factory hfcm from a 6.7 if you don't have plans to add more power
  #3
Old 11-14-2017, 05:28 PM
Corporal
Member's Gallery
Default
do I ****** my fuel bowl with the 6.7 hfcm?
__________________
  #4
Old 11-14-2017, 05:33 PM
Corporal
Member's Gallery
Default
When I say I don't plan on adding power, I mean no more after whatever power a fuel system might add...
__________________
  #5
Old 11-14-2017, 06:19 PM
sootie's Avatar
General
Member's Gallery
Default
Quote:
I would keep the upper filter. since when was a fuel system a power adder? it just helps you keep your injectors alive
  #6
Old 11-14-2017, 07:05 PM
Magnum PD's Avatar
Magnum PD Magnum PD is offline
General
Member's Gallery
Default
I recommend getting a regulated return
__________________
96 F-350 RC 4x4 Hypermax Rods, PIS 300/200s G head tunes, Garrett GT4294, Beans IDM, ARP head & main, girdle, half filled block, DI cam, ceramic coated bowls, anti-friction skirts, Haldex pump over Honey Badger Jr, Diesel site High volume lpop, Billet intake Plenums, Dual SD pumps, Fluidampner, beehive springs, cosmetic head gaskets, Inconel valves, hardend guides, Ported and polished heads by me, home made RR fuel, 5 speed tranny, with SB 3600 DxD. Snow water meth.
  #7
Old 11-14-2017, 07:31 PM
lariat 7.3 lariat 7.3 is offline
Lieutenant
Member's Gallery
Default
Quote:
sig says he already has one
__________________
2000 F250 ccsb 4x4. 297k miles, Leveled 05 coil spring swap on 20x12 35's, 38r 1.0 housing with turbo master, 238/80% FFD hybrids,T500, Full sinister RR stainless with bowl removed and Dual Bosch pumps. GH tunes on Hydra, BTS DIESELSITE Boots, Autometer C2 series gauges, DIY tymar, remote start. 08 mirrors. dual Fox Resi Shocks
  #8
Old 11-14-2017, 07:43 PM
Magnum PD's Avatar
General
Member's Gallery
Default
Didn’t see that.
__________________
  #9
Old 11-18-2017, 03:28 AM
emev0l's Avatar
emev0l emev0l is offline
Sergeant
Member's Gallery
Default
I've sold and installed several of the Irate and Driven Diesel fuel systems with Fuelab pumps. They'r both great kits. Irate does have a slightly cheaper kit that will work for your size injectors that used a Deatsch Werks pump, I only have 1 customer with one, zero issues.
__________________
99 RCSB s468, 350/200, BTS, Twin Terminators, Crowers, A1000, Colt Cam, Headers, Cryo'd block, Girdle, De-lipped/Ceramic/Teflon Pistons, 05 front axle 666rwhp
Retired - 99 ccsb, s468, 238/200, BTS, Twin Terminator, ARP, 910, RR, Trutrac, 573rwhp
  #10
Old 11-19-2017, 05:36 PM
superpsd's Avatar
superpsd superpsd is offline
Major
Member's Gallery
Default
What's pressure like on your maxed out tune.
__________________
97-250 7.3 Eaton TVS Supercharged, S369sxe, R&D IDI performance T4 mount, my B350/200s, Honey Badger SR with My tunes, BMW M3 seats, Sky 5" RSK skyjacker drop pivot brackets, Sky shackles and hangers, Toyo M/T
1948 GMC Detroit 453T - 1945 Chevy C30 GM 451 - 1951 Mack A51T under restoration
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
Designed by Military Ltd
