Power loss , intake flutter
eng53ine
Ohio
2005 6.0, auto, 4x4, ccsb, xlt, 88,792mi.
Been having an issue arise where the truck will lose power, still has throttle but acts like it wants to die. The first time it did it was highway speeds , starting stuttering, flutter in the airbox white smoke. Pulled to the shoulder came to a slow stop, sit there for aprox. 30 seconds truck running all was fine.
That was about a week or two ago, last night it did the same thing. It was dark couldn't see any smoke, didnt stop just limped it for about half a mile and it was fine again. It does't dead pedal but doesn't want to go when throttle is given. No lights are thrown either.
Tablet was dead while it was doing it last night but did run it after i got home,and was back to running normal also don't know if im watching the right stuff or not.
Only codes are, p0470, and cylinder 3,4,7,8 glow plug circut.
Sent from my SM-T113 using Tapatalk
Mesa, AZ
Check your ebp vs map and baro koeo. They should be relatively close to each other. Ford says within 1.5 psi, typically theyre closer than that.
eng53ine
Ohio
Map& baro 14.3, ebp 14.5, i didnt add the map first ebp was 14.7, baro was 14.3. Started the truck reread your post shut it off and added map, those were key on engine off
bismic
Try running w/ the EBP sensor disconnected.
Also, monitor v-reference voltage
eng53ine
Ohio
Ok will do, what is v reference voltage?
Also just went to the decided to give it a little fuel to see if it would do it again. Noticed felt sluggish, watched the mirror and was putting out black smoke. Left it idle probably 5 minutes while in the the store, did wiggle the pigtail on the turbo before leaving. Truck put out one puff of black smoke and was running perfect putting out no smoke. Could it be turbo related?
Zeb
Downtown Marrowbone Ky
Still have the egr cooler and valve? I have seen them act very similar to this when the egr system is intact and the valve randomly sticks open.
eng53ine
Ohio
Yes I believe everything is intact, it belonged to an older man supposedly and I have done anything to it.
Is there a way to check the egr or does it have to be pulled to be inspected?
Zeb
Unplug it and it should default closed. You’ll probably get a CEL, but it will run fine. Run it and see if the problem stays gone, or continues.
eng53ine
Ohio
How long should it be run like that? Or wait and unplug when it starts doing it again. Also thought about ordering the orings and pulling it to see if it needs cleaned.
Zeb
However long you want. I ran my Excursion for 2 years like that. No CEL on it.
Mesa, AZ
What zeb said. Also, the pigtail for the vgt isnt broken is it? If you messed with it and it ran better, could br an issue there, or chafed wires right at the end of the hard shell
eng53ine
Ohio
It didn’t appear to broken, but I thought it seemed loose like you can wiggle the male part inside of the female side.
eng53ine
Ohio
So far no more issues, what would i be better off to do? Pull it and clean it , lose it or leave it alone?
