Go Back   PowerStrokeArmy > Power Strokes > Aftermarket Super Duty 1999 - Current
Reply
Thread Tools Display Modes
  #7481
Old 12-15-2019, 09:13 PM
6.0 Tech's Avatar
6.0 Tech 6.0 Tech is offline
Colonel
Member's Gallery
Default
Quote:
Originally Posted by Magnum PD View Post
A bigger atmo turbo? Quicker spool?
Yeah bigger atmo, didnt really seem to change anything to be honest. Charlie needed my 476, so he gave me the 88 to throw on in the meantime. I saw maybe a couple more psi, from like 57 with the 76, to it touched 60 for a second or two before it shifted, but honestly no real difference. I am way under fueled right now as it is, only running 190/30s. And honestly with the 250/100s it was squeaky clean after about the 100ft mark on the drag strip, so I didnt figure yhere would be any change, and if any, it would be for yhe worse.
__________________
04 cclb IDP and TSD tunes, KC Stage 2 hi pressure, S476 atmosphere, Odawg Stage 2 ported intake, RCD Stage 1 cam, RCD lifters and pushrods, RCD 120# valve springs, ARP 625s, o ringed heads, Warren 7mm 250/100 hybrids, Strictly bowl dereete regulated return, Air Dog 2 4g, Snow stage 2 water/meth
  #7482
Old 12-15-2019, 09:24 PM
lincolnlocker's Avatar
lincolnlocker lincolnlocker is offline
General
Member's Gallery
Default
You wouldn't see much boost difference but should push more air. you would see and feel a difference if you had big 300+/◊◊◊ injectors.
__________________
00,f350,4x4,cc,drw. Sold... good bye ole girl. I will miss you
15,f350,4x4,cclb, not stock
  #7483
Old 12-15-2019, 09:29 PM
6.0 Tech's Avatar
Colonel
Member's Gallery
Default
Thats the plan eventually. Built motor, 330/150s, KC stage 3 and 488, and some giggle gas... All it takes is some money, and time. Neither of which I have extra of at this time.
__________________
  #7484
General
Member's Gallery
Default
That will be a fun mofo!!!
__________________
  #7485
Old 12-15-2019, 09:30 PM
6.0 Tech's Avatar
Colonel
Member's Gallery
Default
Lol, yeah, I'm hoping it will tow ok...
__________________
  #7486
Old 12-22-2019, 05:10 PM
Magnum PD's Avatar
Magnum PD Magnum PD is offline
General
Member's Gallery
Default
I’m Hoping I got my fuel leak fixed. After redo the return line and a second hose, I took the AC, vacuum and power steering pump assembly off I was expecting to see the fuel rail plug leaking, but it turned out to be my AN fuel connection wasn’t tight. Couldn’t get to it without taking the above assembly off. Pressure washed everything and at the moment don’t see an puddles.
__________________
96 F-350 RC 4x4 Hypermax Rods, PIS 300/200s G head tunes, S471, Beans IDM, ARP head & main, girdle, half filled block, DI cam, Dual IPRs, ceramic coated bowls, anti-friction skirts, Haldex pump over Stock pump, Diesel site High volume lpop, Billet intake Plenums, Dual SD pumps, Fluidampner, beehive springs, cosmetic head gaskets, Inconel valves, hardend guides, Ported and polished heads by me, home made RR fuel, 5 speed tranny, with SB 3600 DxD. Snow water meth.
  #7487
Old 12-22-2019, 05:27 PM
Tom@BigTimeKustomz's Avatar
Tom@BigTimeKustomz Tom@BigTimeKustomz is offline
Sponsor
Member's Gallery
Default
A much needed bath and annual Christmas photo with the truck yesterday.
__________________
Big Time Kustomz Diesel and Off-Road Performance
2013 F350 CC/LB - Sterling Gray, Lariat Ultimate, 22X12 FF19's, Toyo Rubber, MPD 364.5 Turbo with Piping Kit, iPad Dash kit, Amp Steps, Bilstein Suspension
Contact me for great pricing on the industry's leading products tom@bigtimekustomz.com
  #7488
Old 01-29-2020, 07:06 PM
StrokiNDieseL's Avatar
StrokiNDieseL StrokiNDieseL is offline
Lieutenant
Member's Gallery
Default
Just starting removal of essentialís. Damn upper fuel filter is stuck and wonít budge 🤬..
File Type: jpg B6FD5F82-571B-485A-B145-F97D3FB9FE14.jpg (25.3 KB, 45 views)
__________________
Slow stock 17 F250 6.7L Ccsb Lariat ez lynk Em on tooning 75hp, Pmf reverse level.
08 Sclb 6.4 Farm truck Minimaxx on a diet (project 6far)
08 F250 Built 6.4L CcSb Lariat 3.73 Dyno'd 704rwhp/1220tq. SOLD
  #7489
Old 01-30-2020, 10:28 AM
Connor M's Avatar
Connor M Connor M is offline
Lieutenant
Member's Gallery
Default
I have something similar to do on a work truck soon. Trying to figure out what the best solution is when I get pulled over by DOT. Thinking hollow everything out or block it off and just play dumb.
__________________
2008 CCSB 6.4 Harley Davidson- PPEI Tuned, EZ Lynk, 4" Jamo Stainless Exhaust, Diet Coke, 35x12.5 Cooper Discoverer STT Pros- Down But Not Out
2008 CCLB 6.4 Lariat Land Yacht- H&S tuned, S&B intake, Diet Coke
2008 EC C&C F450 6.4 Work Truck- Build Loading
2003 RCLB 6.0 XLT- 260,000 miles, no name tunes, stock as can be
6.0 Dump Trucks- 350 and 450
VT365 Rollback
  #7490
Old 01-31-2020, 04:57 PM
General
Member's Gallery
Default
Quote:
Hallow it out and if there is room then add a resonator and muffler so it stays quiet and ninja like
Sent from my SM-G977U using Tapatalk
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
Designed by Military Ltd
