Require aftermarket v-band
Extended Power
Looking to change the hose connection, from the primary turbo to the piping on my setup, to a v-band connection.
I would like to use a v-band that has an o-ring seal inside.
One half would be aluminum, the other, mild steel.
Don't care if I have to but two separate v-band assemblies.
Any suggestions?
Extended Power
Found a supplier, that I have used in the past, has them.
Stainless flange on one end, aluminum on the other...under $60.00 delivered.
