dually conversion questions
tyler2k
I have a 97 f250 extended cab 8ft bed, I'm looking to do a dually conversion and solid front axle. I have a junked 97 f350 with a dump body that I believe is cab and chassis, can the rear and front axle be swapped? I plan on ditching the bed and building a flat bed I don't know if that matters
Strokersace
Towanda, KS
Front will work fine. The c&c rear axle can work, but the frame widths are different as are the spring perches on the axle as well as other items. If you’re handy with fabrication, you can surely make it work. But the rear axle won’t be plug and play like the front.
tyler2k
is it super involved, I got the c&c truck for free and plan on towing a 5th wheel in the future that a f250 isn't enough for I need the dual wheels
Bugman
Gypsum, Co
I would start looking for a F350 with the dual wheels.
No matter what you do to that F250 it will always be a F250 and if something should happen after you convert it over to a dual wheel truck while towing the 5th wheel it will be on you. Odds are your insurance company will deny the claims and you will be sunk.
But other than that it has been done but you need to be able to fabricate and weld to get everything to fit right and even then you may have problems.
Diabolic
Besides the axles and springs, what’s the real difference between the F250 and the F350?
Jonnydime
Absolutely nothing. Except the door sticker LOL. As long as your are registered for the weight you will be fine. My F250 is registered at 13,300lbs gvrw.
Bugman
Gypsum, Co
You really need to talk to your insurance carrier about that.
It doesn't matter what you register a vehicle for as far as weight is concerned, the factory capacity is the capacity that you need to go by as far as laws are concerned. And if you get into a wreck carrying over the factory capacity and it was due to the weight that you were hauling odds are your insurance company will decline any and all payments.
Jonnydime
I’m not gonna argue but think about this the dot won’t put you out of service until you are more the 6,000lbs overweight.
Bugman
Gypsum, Co
I agree it is a argument that neither one of us will win and it will go on forever.
I am just talking what your insurer will do and not the DOT.
Insurers will look at any reason to get of of paying a claim and running a F250 overloaded will be one of the first things that they look at.
Ad8 PRODIGY
Orange County, NY
Strokersace is on the right path but not 100 correct.. i learned the hard way the c&c rear axle is narrower overall. Went to put it in mu f250 frame, bought new leaf perches, cut the old ones off and welded the new ones on and got it under the truck. Put inner dual on and was about a half inch out from getting it in to the hub. Tires (granted they were 285/75/16s) rubbed the leaf springs bad.
Better off finding a pickup f350 sterling 10.25 and swapping it directly in with no modification.
Sent from my SM-G955U using Tapatalk
tyler2k
im located in central Jersey. and my truck has the extended cab the other one is only single cab. basically im looking to tow a 05 keystone raptor fifth wheel. my father tows it with a 97 chevy 3500 dually with added airbags, I'm gonna guess the f250 won't be enough
wildbill963258
In Lawrenceburg, Kentucky
Put 1 ton springs in the back and box the frame that's a whole lot easier than making your truck a dually, I could be wrong but I dont think theres much if at all of a difference of towing capacity between 1ton dually and 1ton srw.
wildbill963258
My 96 that I had it was a 250 but the company that owned it before beefed the rear suspension up so much that the only way it rode smooth was if you had about 3k lbs in the back of the truck and that would honestly be the easier and safer way than doing a drw conversion
tyler2k
I believe I have 350 springs already, if there is a difference, I was thinking maybe airbags could help to. im not sure the exact weight of the trailer but the thing is huge
C2tuck
North Texas
Guess I need a dually...15-16k loaded granted it’s not an old body style.
psduser1
on the road
That's only about 25-2800 lbs on the pin.
A GOOD set of tires, and airbags, youd be in business, if you aren't trying to pull it as an everyday thing.
Just up the maintenance schedule on the differential, and keep track of the brake condition.
The DOT and insurance question is a separate issue, depending on the state you operate in.
