Go Back   PowerStrokeArmy > Premium Vendors > DP-Tuner
Reply
Thread Tools Display Modes
  #1
Old 02-02-2016, 01:34 PM
Justin@DP-Tuner's Avatar
Justin@DP-Tuner Justin@DP-Tuner is offline
Major
Member's Gallery
Default New 7.3L turbo option available!
As many of you know, we have carried the Bell HFSB turbo for quite some time, and have had much success with it. It is a very popular turbo option for the person looking to make up to around 550HP. We now have another option for the 7.3L world! That is the Bell FSSB turbo. This turbo utilizes the popular T4 style mount and features a smaller turbine housing compared to the HFSB. This leads to a quicker spool and better throttle response. It shares the exact same compressor wheel as the HFSB turbo, so it moves a lot of air! This turbo is a great option for someone looking to make 350-500HP.
So to sum things up...
HFSB: T4i style mount and good for 425-550HP. Larger exhaust housing provides lower drive pressures and better performance for higher RPM (towing) and higher HP applications.
FSSB: T4 style mount and good for 350-500HP. Smaller exhaust housing provides quicker spool up and response, which is ideal for daily driving applications.
Both turbos utilize the same exact compressor wheel and both have the option for a billet wheel upgrade.
We also offer the Carson Stauffer Diesel mount kits for both of these turbos, so you can pick everything up at one place.
Check out the new Bell FSSB here... http://www.dp-tuner.com/ford-powerst...ssb-turbo.html
Check out the Bell HFSB here... http://www.dp-tuner.com/ford-powerst...fsb-turbo.html
Feel free to contact us with any questions you may have!
__________________
Justin
Like us on Facebook!
www.dp-tuner.com
  #2
Old 02-15-2016, 12:59 AM
Footz09's Avatar
Footz09 Footz09 is offline
Corporal
Member's Gallery
Default
Nice , pretty soon , pretty soon
__________________
03 F250 4x4 - Irate Diesel BASB turbo w/T4 Kit , 180/80 sticks ,stage 2 trans w/stallion , 4" exhaust , Big Boost intake , DynoProven regulated return (80% redone) , Strictly Diesel Duel SD pump fuel system, DP-Tuner F6 live tunes ( thanks Jody) DynoProven Honeybadger Sr HPOP , full isspro layout , coolant filtration sinister ,oil filtration ncu , Dieselsite trans filtration ,35" tires , 6.0 tranny cooler and intercooler complete killer full JL audio system . All Schaeffer oil in all
  #3
Old 02-15-2016, 10:15 AM
cjfarm111 cjfarm111 is offline
Lieutenant
Member's Gallery
Default
Sooooooo what happened to the BSFB?
  #4
Old 02-15-2016, 05:46 PM
Major
Member's Gallery
Default
Quote:
Yes, it is another option for the 7.3 turbo market and a very good one at that. Feel free to contact me with any questions you may have about it.
Quote:
BSFB? Kind of confused as Bell does not have a turbo by that name.
Do you mean the HFSB? If so, it is still an available option on our site.
__________________
Justin
www.dp-tuner.com
  #5
Old 02-15-2016, 06:38 PM
Baker42's Avatar
Baker42 Baker42 is offline
Sergeant
Member's Gallery
Default
Im more interested in the S369 sxe on a 7.3 truck as I just ordered one. Not trying to hijack but Im curious to hear from anyone running 1
  #6
Old 02-15-2016, 07:36 PM
Constructionworker Constructionworker is offline
Sergeant
Member's Gallery
Default
Do you have any other turbo option for a 96 OBS? This is a work truck that I've been told stage one injectors are perfect for and would like to upgrade the turbo one day but can't see spending 2800 on a turbo.
  #7
Old 02-16-2016, 05:21 PM
Major
Member's Gallery
Default
Quote:
Unfortunately, there is no good drop in turbo upgrade for an OBS. The only non-stock turbo available for drop in is the D66 which, IMO, performs worse than stock.
The reason for the higher price with kits like this is that they come with all new mounting components. This includes bellowed up-pipes, oil feed, oil drain, pedestal, etc...
You can run stage 1 injectors with a stock turbo and it will work okay. Adding an intercooler will really help though.
__________________
Justin
www.dp-tuner.com
  #8
Old 02-16-2016, 07:14 PM
Sergeant
Member's Gallery
Default
Would I be better with stock injectors? It's tough to spend more money on stage 1 injectors and the turbo kit than what the truck is worth. Just trying to find the best combo for my work truck
  #9
Old 02-17-2016, 02:10 PM
Major
Member's Gallery
Default
Considering that stage 1 injectors are only about $100 more than stock replacements, it would be wise to go with them and add an intercooler to the truck. You can pick up a used SD intercooler fairly cheap and you can make it work. Then, when you have some more money to spend on the truck, do a turbo upgrade.
__________________
Justin
www.dp-tuner.com
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
