Go Back   PowerStrokeArmy > Power Strokes > 7.3 Tech
Reply
Thread Tools Display Modes
  #1
Old 07-11-2018, 10:25 PM
sparky sparky is offline
Private
Member's Gallery
Default 2000 7.3 torque converter locking unlocking
My 2000 7.3 4r100 the torque converter locks and unlocks while accelerating and driving in OD. I have ohmed out the solenoid pack and wires going to it. I have replaced brake light switch, tail light bulbs. Can’t find anything anyone have any ideas. I am leaning toward PCM or solenoid pack it’s self.
  #2
Old 07-11-2018, 10:28 PM
DieselDC's Avatar
DieselDC DieselDC is online now
Sergeant
Member's Gallery
Default
How many miles on it? Could be just worn electrical checked out. Could be the valve body too.
—————signature—————
~Don’t overthink something simple~
...:uptight people suck:...
  #3
Old 07-12-2018, 07:33 AM
Private
Member's Gallery
Default
300000 in pickup 150 on valve body 75000 on transmission rebuild
  #4
Old 07-12-2018, 08:16 AM
DieselDC's Avatar
Sergeant
Member's Gallery
Default
When you homed our the solenoid pack, what did you get?
I believe 4r100 uses the speed sensors on the transmission itself for lockup (along with pressure fluid coupling etc). Could you ohm them out too? 1.10 ohm
—————signature—————
  #5
Old 07-12-2018, 08:30 AM
Private
Member's Gallery
Default
That is the chart I used
  #6
Old 07-12-2018, 09:02 AM
mandkole's Avatar
mandkole mandkole is offline
Major
Member's Gallery
Talking
Can you command lock and keep it locked? You also should put a scanner on to verify if the converter clutches are slipping while locked. If it is, it will command unlock. I chased this troubleshooting path until pulling the trans and replacing the converter.
__________________
2000 F250 CCSB GT4294R, 250/100s, Dahl/Fuelab, BTS, PHP tuning, stock 17* pump
1994 F250 SCLB
(sold)
1997 F250 CCSB 2wd (sold)
  #7
Old 07-12-2018, 03:46 PM
Private
Member's Gallery
Default
They are not slipping it is locking and unlocking several times with in a few seconds I have a snap on Solis scanner and you can see it doing this.
  #8
Old 07-12-2018, 06:19 PM
Private
Member's Gallery
Default
If I ground it using a toggle switch it works good
  #9
Old 07-12-2018, 06:28 PM
DieselDC's Avatar
Sergeant
Member's Gallery
Default
Not solenoid since it ohms out fine. Not tc b/c you locked it manually.
Pcm. Get it rebuilt by swamps.
—————signature—————
  #10
Old 07-12-2018, 07:46 PM
mandkole's Avatar
Major
Member's Gallery
Default
Quote:
10-4.. does it stay cool when locked? It will stay command locked on a ground switch, but doesn't necessarily mean it's happy.
__________________
1994 F250 SCLB
(sold)
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
