4" Ball/Socket Style Downpipe-Ford 6.4 Powerstroke
Cromwell, CT
Our SDP 4" Aluminized Downpipe that fits the 2008-2010 Ford 6.4L Powerstroke. This pipe is designed to bolt in as a replacement for the stock downpipe. It will allow the CAT/DPF to bolt up to it, which should be a great help if you need to put them back on. It also allows ANY downpipe back exhaust to fit without cutting. Install time is about 1 hour.
*ceramic coating can be added for $50.00.
