Go Back   PowerStrokeArmy > Power Strokes > 6.7 Tech
Reply
Thread Tools Display Modes
  #1
Old 10-15-2020, 10:45 AM
Texan6Seven Texan6Seven is offline
Corporal
Member's Gallery
Default Oil residue in intercooler piping
I’ve had the MPD budget 364.5 kit with full piping and CCV kit on my truck now for 100k miles. I did a boost leak test on the truck as it felt like it wasn’t running as well as it did when I initially installed the kit. Well, when I pulled the intake piping off the turbo inlet I found what I feel is more than usual oil residue on the turbo inlet. Anyhow, I did find a pinhole in the welding on the intake plenum where the two CNC parts are welded together. I pulled the cold side pipe off to get a good ground to TIG the pinhole up and also found oil residue in the intake plenum.
Where could I be getting oil residue from if all CC recirculation is bypassed?
__________________
2013 CCSB, 335k, Carli 4.5” Commuter with Deavers, ICON trac bar, Fox steering, V Rock 20x12, 35” Toyo RT, AmpPro stereo integration w/5V signal, Alpine amps, Image Dynamics 6.5” comp all around
  #2
Old 10-15-2020, 10:54 AM
sootie's Avatar
sootie sootie is offline
General
Member's Gallery
Default
Turbo seals
  #3
Old 10-15-2020, 12:12 PM
Corporal
Member's Gallery
Default
While I had the intake piping off, I checked for shaft play on the impeller shaft and did not feel any. As far as turbo seals, what would cause those to fail (besides a dirty intake filter)? I ran the filter that came with the kit for about 50k miles. I then switched to the Donaldson B085011 filter for better filtration. Could that have had any negative effects?
__________________
  #4
Old 10-16-2020, 06:41 AM
SDER1 SDER1 is offline
Private
Member's Gallery
Default
Sub'd ....would a ccv reroute result in potential turbo seal failure, or would other conditions lead up to this, such as what the OP suggested - dirty air filter?
__________________
- Will
2006 F350 CC SB / OEM Air box / Zoodad / SCT / ScanGauge II / MBRP 4" TB w/Kitty MIA / CCV Mod'd / Blue Spring / 6" Fabtech lift (want a 4 or 4.5") /35" FC-II & 18" Moto Metal / Cobra 75WX / Wilson 500
"SOLD"
2017 F350 CC LB / "Stock" / 285/75R 18 Nitto AT G2
  #5
Old 10-16-2020, 03:35 PM
Corporal
Member's Gallery
Default
I’ve been doing some research and I found a pretty informative video about the oiling system of turbos. In there it says that one contributing factor to finding oil in either the intake or exhaust side of your turbo is excessive engine blow by or, if you have a larger turbo (they specifically mention s300/s400 turbos) is that if your vehicle idles for extended periods of time, that the turbo shaft doesn’t spin fast enough to sling the oil out and away from the piston ring of the shaft. I believe that’s the issue I’m having.
Here is the video:
https://youtu.be/hGSoe-sZcXk
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
Designed by Military Ltd
