Go Back   PowerStrokeArmy > Power Strokes > 2017+ 6.7 Aluminum Super Duty
Reply
Thread Tools Display Modes
  #1
Old 01-12-2018, 08:30 AM
DuvalJohn DuvalJohn is offline
Private
Member's Gallery
Angry Traction control sucks!
Guys,
I want to WOT ON A MUDDY ROAD!
I hunt and at times donít want to use 4wd. But with traction control & autotrac off, the truck still DE-tunes when the wheels break lose. Whatís the fix?
Ez-lync & Forscan?
Thx for any help
  #2
Old 01-12-2018, 08:55 AM
mikeeg02 mikeeg02 is offline
Lieutenant
Member's Gallery
Default
On the 11-16s you can disconnect the drivers front abs sensor down by the link arm. Retains Speedo and cruise. Disables abs/traction control/advanced track. I keep mine disconnected all the time. I cannot stand anything that takes away my ability to use the brake pedal. Or gas pedal for that matter.
__________________
285k+ for miles, 238/100s for fuel, T500 for oil, 366sxe for air, ge@rhead for tuning, DRW for towing and myself for shifting gears. Pushrods, beehive springs, arp studs... trying to quit........
  #3
Old 01-12-2018, 04:06 PM
8WR_ZJ 8WR_ZJ is offline
Lieutenant
Member's Gallery
Default
I have a switch I flip on and off that breaks the fuse. I got this idea from another member. It's called a "fun switch". Works great throws abs light and brake light on dash. After about 3 minutes of driving the wrench comes up. But as soon as i flip it back everything works great. No lights no wrench. My truck is an 15 model.
I will get the fuse number and stuff in a bit. And a pic.
Sent from my SAMSUNG-SM-G891A using Tapatalk
__________________
2015 F-350 CCLB 4WD, S&B, GH SOTF, 4" FLOPRO, FUN SWITCH.
  #4
Old 01-12-2018, 04:08 PM
Lieutenant
Member's Gallery
Default
My '12 is a gasser, if I pull the fuse I lose my speedo. The diesels may be differents.
__________________
  #5
Old 01-12-2018, 05:02 PM
Private
Member's Gallery
Default
Thx!
  #6
Old 01-12-2018, 06:54 PM
04cr450's Avatar
04cr450 04cr450 is offline
Major
Member's Gallery
Default
Why do this when u can disable the traction control by holding down the tcs button for a few seconds disabling the advanced trac control. 17's different?
__________________
16 250 tri-coat white, 22x12 AF satin black traxx with 325/50 terra g2, no limit goodies, flo pro exhaust, sct x4, recon smoked side and cab lights, retro solution led head and fog lights, icon 2.5" leveling kit with fox 2.0 shocks.
  #7
Old 01-12-2018, 06:57 PM
Lieutenant
Member's Gallery
Default
I think advanced trac re-enables after a certain speed. And I don't want to have to turn it on every key cycle.
That's my reasoning anyways.
__________________
  #8
Old 01-12-2018, 06:58 PM
04cr450's Avatar
Major
Member's Gallery
Default
I believe it only resets after shutting down the truck. I understand though
__________________
  #9
Old 01-12-2018, 07:24 PM
Lieutenant
Member's Gallery
Default
I thought it was over 45 mph and it enables. I know I can turn of by the TCS button and it shuts down when the tires spin at 55. With the fun switch it does nothing.
__________________
  #10
Old 01-12-2018, 11:55 PM
Dusten's Avatar
Dusten Dusten is offline
Sergeant
Member's Gallery
Default
Forscan turns it off
__________________
2008 Ford F-250 lifted/studs/tuned
2001 Ford Lightning - Built motor - Built trans - 2.3 KB - Custom Interior - Garage Queen
1993 Ford Lightning - stockish
1994 Ford Cobra - stockish
1968 Mustang - Gold Nugget Special - restored
2017 Ford F-350 CCSB
2015 Hyundai Sonota Sport
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
