5" exhaust tip
Kbuterbaugh04
Strolling through Google looking at 5" exhaust and across this picture. Reason it caught my eye was it's a oval tip, 5", and chrome that came out at the same angle the oem exhaust did. I don't particularly care for the angle cut tips that are pointed more at a angle away from the tire and it seems nobody makes a 5" tip non angle cut that's 5" Id and 5" od.
I don't care for the Cummins fad of tips you can throw a body in (exaggeration) and the 5" is just right.
Any help?
Kbuterbaugh04
There is one they sell on Ebay like this but it Is only a 6" that I have found.
http://www.ebay.com/itm/DODGE-RAM-D...Parts_Accessories&hash=item1e8ea4bcf7&vxp=mtr
If it wasn't for the 6" outlet I'd be more than pleased with that. That extra inch is enough to bother me, I know I know, too particular.
I may have to cut a section off and send it to be powder coated a silver or have it dipped in chrome. Then buy a 5" to 5" exhaust adapter to re-connect the two pieces. I don't know of anybody than can flare a 5" pipe to 5.25" so I can use a regular band clamp.
We have salt here and doesn't take long to change to rust colored.
Kbuterbaugh04
Found another solution (looking for feedback)
I noticed the kenworth's have a 5" elbow on them with a flared end where it connects to the mid pipe. And found this at online chrome shop
Kbuterbaugh04
As long as the pipe after the muffler would be straight and at the right angle. Which is why I haven't pulled the trigger on an exhaust just yet
bad moose
Valley Center KS
I think you need to be looking at a 45 degree instead of a 90 degree. If you look at your first pic, it looks like more of a 45
Kbuterbaugh04
I've found a couple, but most just galvanized.
Hypothetically would it hinder any performance to insert a reducer at the end of the exhaust to accept a 4" inlet, 5" outlet tip?
Seems like a easier way to ensure the finished look I want. Or would it alter the exhaust sound?
Kbuterbaugh04
It's gonna be for a 5" I think I may just go with a reducer since I found them widely available unless I can find a 5 inch straight cut that's 5 inch on the outside as well.
5 inch exhaust to a 5" to 4" reducer to a 4" to 5" exhaust tip. Unless I can find thay tip
Kbuterbaugh04
Found the company that installed that exhaust. Pela motorsports?
It's a 5" turbo back Flo pro ss614 with a chrome sweep tip
Hope this helps anybody in the future
