Go Back   PowerStrokeArmy > Power Strokes > 7.3 Aftermarket
Reply
Thread Tools Display Modes
  #531
Old 01-22-2018, 04:38 PM
gwunter's Avatar
gwunter gwunter is offline
Lieutenant
Member's Gallery
Default
Guessing you already found this, but I was bored.
http://powerstrokearmy.com/forums/sh...6233&showall=1
Looks like you've even posted in that thread. Look
This looks like a simple to make item.
__________________
Just a crazy, wannabe machinist....making crazy stroker parts.
  #532
Old 01-22-2018, 05:46 PM
DieselDC's Avatar
DieselDC DieselDC is offline
Sergeant
Member's Gallery
Default
Benefits of dual IPR?
  #533
Old 01-22-2018, 07:37 PM
Magnum PD's Avatar
Magnum PD Magnum PD is offline
General
Member's Gallery
Default
Still have details I don’t know. Do I come out of the IPR outlet with something like this,
https://rover.ebay.com/rover/0/0/0?m...2F162776843694
Then t off into a block where the oil coming into the end of the IPR. Gotta find what the dimensions are for the 2 different circumference of the IPR are. One going in and the bleed off for the bigger dimension. Gonna need another port for the bleed off of EACH IPR. If that can be done with one port, idk. The thread linked had the ICP sensor at the block also. That’ll have to be apart of the oil coming in. I’m not a designer of mechanical hydralic blocks. Need to know what thread the IPR is. NPT, SAE, metric or bolt threads. Take the return back to th HPO Rez?
__________________
96 F-350 RC 4x4 Hypermax Rods, PIS 300/200s G head tunes, Garrett GT4294, Beans IDM, ARP head & main, girdle, half filled block, DI cam, Dual IPRs, ceramic coated bowls, anti-friction skirts, Haldex pump over Honey Badger Jr, Diesel site High volume lpop, Billet intake Plenums, Dual SD pumps, Fluidampner, beehive springs, cosmetic head gaskets, Inconel valves, hardend guides, Ported and polished heads by me, home made RR fuel, 5 speed tranny, with SB 3600 DxD. Snow water meth.
  #534
Old 01-26-2018, 07:44 PM
Magnum PD's Avatar
General
Member's Gallery
Default
Trying to put together a layout for the dual IPR block. Got some measurements and ideas from the other thread linked
__________________
  #535
Old 01-26-2018, 08:04 PM
DieselJpower's Avatar
DieselJpower DieselJpower is online now
Lieutenant
Member's Gallery
Default
Figure the tuning out. I have tunes that act funny with the gen3, then switch to another set of tunes and it's perfect. You have an underlying issue or the tuning needs fixed.
__________________
Josh
02 CCSB F350 4x4 -- GONE
04 Excursion 4x4 -- GONE
05 Excursion 4x4
19 CCSB F350 4x4
  #536
Old 01-27-2018, 01:38 AM
Magnum PD's Avatar
General
Member's Gallery
Default
I first used Dyno then switched to G head so, those two didn’t help.
__________________
  #537
Old 01-27-2018, 07:43 AM
Lieutenant
Member's Gallery
Default
I did the same. I'd call Dan K or Jelibuilt, they both run a gen3 on their rigs I believe.
__________________
Josh
05 Excursion 4x4
19 CCSB F350 4x4
  #538
Old 01-27-2018, 07:50 AM
mikeeg02 mikeeg02 is offline
Lieutenant
Member's Gallery
Default
I can't remember. But have you explained your symptoms to ge@rhead and gotten tuning revisions ? You've verified things work well minus the gen3, before you add something else to the mix, see if ge@rhead can tune it in. May take a few tries since it's remotely dine. But they will work with you.
__________________
285k+ for miles, 238/100s for fuel, T500 for oil, 366sxe for air, ge@rhead for tuning, DRW for towing and myself for shifting gears. Pushrods, beehive springs, arp studs... trying to quit........
  #539
Old 01-27-2018, 01:12 PM
Magnum PD's Avatar
General
Member's Gallery
Default
I can give them a call.
__________________
  #540
Old 02-08-2018, 04:21 PM
Magnum PD's Avatar
General
Member's Gallery
Default
Got truck inspected and now it’s legal to drive, so I’ll be driving what I built for now. Competing later.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
Designed by Military Ltd
