Go Back   PowerStrokeArmy > Power Strokes > 7.3 Aftermarket
Reply
Thread Tools Display Modes
  #541
Old 02-25-2018, 12:08 PM
Magnum PD's Avatar
Magnum PD Magnum PD is offline
General
Member's Gallery
Default
I do have motorcraft valve cover harnesses with the injector harnesses coming in tomorrow. Sure hope that will get rid of the miss. Dorman brand on truck now. If it does fix it, Seth gets the credit for fixing it.
__________________
96 F-350 RC 4x4 Hypermax Rods, PIS 300/200s G head tunes, Garrett GT4294, Beans IDM, ARP head & main, girdle, half filled block, DI cam, Dual IPRs, ceramic coated bowls, anti-friction skirts, Haldex pump over Honey Badger Jr, Diesel site High volume lpop, Billet intake Plenums, Dual SD pumps, Fluidampner, beehive springs, cosmetic head gaskets, Inconel valves, hardend guides, Ported and polished heads by me, home made RR fuel, 5 speed tranny, with SB 3600 DxD. Snow water meth.
  #542
Old 02-27-2018, 07:41 AM
DocBar's Avatar
DocBar DocBar is offline
Major
Member's Gallery
Default
Quote:
I've had nothing but bad luck with Dorman.
__________________
2003 F250 CCSB with a few mods
2011 HD FXDWG Blacked Out
2014 Audi A5 Coupe 2.0T
  #543
Old 02-27-2018, 05:26 PM
Magnum PD's Avatar
General
Member's Gallery
Default
Here’s hoping
__________________
  #544
Old 03-01-2018, 04:12 PM
Magnum PD's Avatar
General
Member's Gallery
Default
I swapped out the Dorman gaskets for Internnational gaskets and still have 2 cylinders not working, one mainly. I might swap injectors to see if it stays in that one particular spot. I did swap my IDM with my brother in laws in his truck and his ran fine. Might have to do a compression test. I’m up for suggestions.
__________________
  #545
Old 03-01-2018, 11:15 PM
gnxtc2's Avatar
gnxtc2 gnxtc2 is offline
Major
Member's Gallery
Default
Run the motor with the valve covers off. Look at the oil spouts and see how much oil is coming compared to the others.
Billy T.
gnxtc2@aol.com
__________________
'97 Black F250HD SC, 3.55s, Punisher Trans, PI Converter, Dana 60 RSK w/ V & C SD springs, PIS 175/80s, T500, Cale's tunes, 910s, Smith Bros, ARPs, Fluidampr, IC, E-Fuel, 3" Plenums, CJC Traction blocks, HFHV IDM, T4/BASB, Horton, 268K
- 2016 F350 DRW Ultimate (stock for now )
- 1987 Buick Grand National (Staged)
- 2004 Mercury Marauder
- 1993 Geo Prizm (beater)
  #546
Old 03-27-2018, 07:21 PM
Magnum PD's Avatar
General
Member's Gallery
Default
Swapped harnesses, pretty sure the miss is gone. Haven’t got all the sensor wires hooked up yet and throwing a CEL. Need to know what wire goes to which sensor. Mainly the single wire sensors. Coolant, oil pressure and the one on the front cover.
__________________
  #547
Old 03-29-2018, 08:24 PM
Magnum PD's Avatar
General
Member's Gallery
Default
The oil temp pigtail wires were bare and was throwing a code. Swapped the sensor and pigtail, no code and took for a drive. So far it’s doing ok. Had to get it on the road to haul cattle. So wish me luck.
__________________
  #548
Old 03-30-2018, 06:57 AM
Magnum PD's Avatar
General
Member's Gallery
Default
Truck did ok. Feels good I got it going and can use it.
__________________
  #549
Old 03-30-2018, 07:50 AM
mandkole's Avatar
mandkole mandkole is offline
Major
Member's Gallery
Default
Yeah, you were in the barrel for awhile.. nice work.
__________________
2000 F250 CCSB GT4294R, 250/100s, Dahl/Fuelab, BTS, PHP tuning, stock 17* pump
1994 F250 SCLB
(sold)
1997 F250 CCSB 2wd (sold)
  #550
Old 03-30-2018, 09:36 AM
lincolnlocker's Avatar
lincolnlocker lincolnlocker is offline
General
Member's Gallery
Default
That's always a great feeling! Good deal man!
__________________
00,f350,4x4,cc,drw, not stock
15,f350,4x4,cclb, not stock
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
Designed by Military Ltd
