Go Back   PowerStrokeArmy > Non - Specific > Suspension, Drive Train, and Tires
Reply
Thread Tools Display Modes
  #11
Old 06-08-2018, 05:59 PM
565edge's Avatar
565edge 565edge is offline
Corporal
Member's Gallery
Default
It looks like lugnut4x4 makes a brake kit for the 05 & superduty's that will clear a 16" wheel. Just a FYI...
__________________
2000 Ford F-350 Dually, 4x4, D-66 Turbo with Billet wheel, .84 Ex housing, 69.84 turbine wheel, Gear Head Tunes on a Hydra, Unlimited 238/80 injectors, Walbro GSL392 Fuel Pump, 6637 Intake, riffraff regulated return, Riffraff FRX and HPX, comp cam 910 springs, smith bros .120 wall pushrods, terminator t-500, riffraff boost regulator, hutch mod, harpoon mod, 4" exhaust, 295's with 4.10 gears. John woods valve body, billet face transtar converter and built transmission.
  #12
Old 06-08-2018, 08:36 PM
blackseven blackseven is offline
Private
Member's Gallery
Default
This is a great thread, I've always wondered about the interchange of axles. I have a 2011 drw f350 and I'd like to swap it out for a wide f450 axle with the bigger brakes. I already have 17 inch wheels, but I'm trying to find one that already has 3.73s to match my rear. I'm guessing a wide front with 3.73 gear doesn't exist. Any advice?
  #13
Old 06-08-2018, 10:34 PM
co04cobra's Avatar
co04cobra co04cobra is offline
Sponsor
Member's Gallery
Default
They didn't make the super 60s with 3.73s. I also don't think 17s will clear their brakes.
__________________
00 cc/sb zf6 F250- Some stuff done always more to do-Fuel 300/200s Air-Garrett 68/94-Oil SRP 1-Airdog to Fuellab
97 cc/sb- zf-5- Work in progress. PMF rsk w/ SD axles. 66 turbo, E fuel, 230/100s. SB DD clutch.
08 cc/sb - Elite bottom end - 2 fuelers, 59vgt/78atmo, Midwest 100% nozzles and coated heads etc....
www.teddavisautos.com
Many parts available for super duty trucks PM me.
  #14
Old 06-13-2018, 10:35 AM
Private
Member's Gallery
Default
Quote:
They did come in the 2014+ trucks, but they never made a wide super 60 housing that came from the factory with the larger 3.73 gears as far as I can tell. There were 2011-206 wide axle DRW F-350's that came from the factory with 17's.
What I'd like to do is find an F-450 front axle from a 2014+ truck, and see what I can swap over. Bonus if I can use the big brakes from the 2014+ trucks, if not, no big deal. The turning radius is the goal.
  #15
Old 09-07-2018, 06:54 PM
rhorsers rhorsers is offline
Sergeant
Member's Gallery
Default
Hope you don't mind me jumping in the thread, but I am trying to get info on my 1999 F350 dually. I definitely want new stock type wheels. Trying to determine if the 08+ wheels can be adapted to the 1999 somewhat "stock".(Such as just swapping hubs). Does anyone know if this is possible without an adapter to change from the 8x170 to 8x200 bolt pattern? How bad is it to swap the coil spring front axle in place of the leaf spring front axle? At the moment I am not too comfortable hauling weight with adapters for the lug pattern. Any help would be appreciated.
__________________
01 F350 SRW CCSB 4X4 ATS Stage 2 Automatic, 3.73 AFE Stage 2, 160/20 split shots, Adrenaline HPOP, 4in Turbo back Sinister Stainless Exhaust, Irate Plenums, Irate T4 with S366 SXE .91 housing
Late 99 F350 CCLB Dually 4X4 6 Speed 4.10 Project Tow Beast Part time daily
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
Designed by Military Ltd
