What EGT temp to monitor on CTS2 for safe shutdown?
dapherdoo2
New to the forum and diesel engine as well. I had a question as to what EGT to monitor on my CTS2 to ensure a safe shutdown to protect the turbo. Love the forum and would appreciate any input.
Thanks
Sent from my SM-G900P using Tapatalk
Just let the truck idle for 30 seconds and it will be cool enough to shut down. Monitoring egts is a good idea when running a big tune or towing heavy. Pre turbo reading is best.
redneck1
Nor Cal
Correct me if I'm wrong, but I believe the main reason in cooling off the turbo is to prevent oil coking. Having a water cooled center section, I doubt you'll every have a problem. It's hard to get down to 350 with it 100 degrees outside running the a/c. I just idle a minute or two and call it good..
Sent from my SM-G955U using Tapatalk
dapherdoo2
Thanks, 48 y/o and learning aomething new every day.
dapherdoo2
This is why I am in a forum...again, learning something new!
Jomax
Arizona
Unless I ran it hard right before I turn it off. I don't wait at all, I just turn it off...
JRLott
TX
I'll start paying attention to EGT. I've parked with oil temps between 197 and 203. If in the lower range, I wait until it drops to 195. If over 200, I wait for it to get down to 197. Never paid attention to egt during that process. It's been over 100 all week here. I know egt cooled off to less than 300 one day, but I was making some phone calls so it idled quite awhile. Good info.
04cr450
harford county, maryland
Me either, I just turn it off.. even with my 6.0's never lost a turbo since 2004 lol even if I run it hard I still just shut it off.....
04cr450
You have to much time on your hands lol jk
JRLott
TX
LOL. Likely true. It gets cranked just before 6. I head to work once I get dressed, coffee, and crap loaded. It doesn't move until oil is over 100, which isn't too hard this time of year. I get to work with oil temps about 195-197. It idles while I put my boots on and is 195 or less by then. Lunch is basically the same except I have to Dick around just a bit to let it cool off slightly. I have plenty of time to let it idle once I get home in the afternoon. Remote start is my friend on those rare occasions that it's hot and I have to get out immediately. Get junk, shut off, get out, remote start, and let it shut down after 5 or 10 minutes. I'm likely wasting more in clatter fluid than I'm saving in turbo. Lol
