02' F550 no brake light but everything else works!?
powerstroker66
pipersville, PA
Just wrapping this truck up and noticed i do not have any brake lights. However, i do have turn signals, flashers, reverse lights etc. The switch has power coming into it and out of it with the pedal depressed. Meters out ohm wise fine too. From research i found that if i dont have turn signals its a bad multi switch since the brake pedal switch impulse goes through the multi switch but that is not the case so i am stumped. My only other thought is a bad clock spring/wrong year column. The column appears to be a 99-01 column and does have a bad clock spring. Could that be the under lieing issue? Thanks all!
powerstroker66
pipersville, PA
yes sir flashers and turn signals all good and work. Power coming in and out of the switch and on the scanner the gen mod recognizes when the pedal is depressed. With out tearing the whole harness apart i dont know where else to look.
