Truck kinda "stutters" while cranking after warmed up
JCart
How many miles on it? When is the last time you’ve installed a Cam Position Sensor on it? Has it been quitting for no reason, say at a stop light? Fires up fine when cold and how cold does it get?
j
DudeManScott
j
230K Miles, I have had it for about 20K. The CPS looks like it might be the original, so changing it would probably be a good idea.
It has never died on my or idled funny. Never an issue in cold weather, which here is only like 30F
Lt.Dan
Visalia, CA
That stutter during cranking makes me think something starter/flywheel related, since it's only happening while cranking and not while running. Maybe get under there and just see if the bolts are tight that mount it to the engine?
