Go Back   PowerStrokeArmy > Non - Specific > Tow-Rig
Reply
Thread Tools Display Modes
  #1
Old 11-13-2017, 09:01 PM
Jeremy t Jeremy t is offline
Private
Member's Gallery
Default Towing with short bed
I have a short bed 2013 f350 Iím in the market for a 5th wheel toy hauler. I was told by a gentleman that since my truck is a 1 ton I can lock the slider hitch in the back position so I wouldnít have to worry about tight turns. Iím not sure if this guy is blowing smoke or not. Iím curious to know if I should trade the truck in for a long bed or if I can just keep this one.
  #2
Old 11-13-2017, 09:33 PM
6.0 Tech's Avatar
6.0 Tech 6.0 Tech is offline
Colonel
Member's Gallery
Default
Lots of people tow fifth wheels with short beds. Mines a long bed, with a b&w companion hitch, so its fixed, im not much help on the slider part. Not sure if id want that much weight behind the axle though. Probably just unlock and slide it back for parking maneuvers and whatnot. Most turns you'll be making on the road arent tight enough to do any damage.
__________________
04 cclb IDP and TSD tunes, KC Stage 2 hi pressure, S476 atmosphere, Odawg Stage 2 ported intake, RCD Stage 1 cam, RCD lifters and pushrods, RCD 120# valve springs, ARP 625s, o ringed heads, Warren 7mm 250/100 hybrids, Strictly bowl dereete regulated return, Air Dog 2 4g, Snow stage 2 water/meth
  #3
Old 11-13-2017, 10:24 PM
gotchadollar's Avatar
gotchadollar gotchadollar is offline
Sergeant
Member's Gallery
Default
I have a turn over ball with the Anderson hitch. It was worth every penny. It tows quite, no metal on metal like the 5th wheel hitches, also i can still utilize my bed because the Anderson only weighs about 45lbs. I tow my 5th wheel with a short bed, no problems at all.
__________________
2015 6.7, 20x12 Sota BRAWLS Wrapped with 285/55/20 Nitto Terra Grappler G2s, EZ Link w/DarksideCals, HS-Motorsports 64.5 Sxe Kit, Dual Fueler, Low Pressure Pump, No Limit EGR, Intake, Suncoast 1900 stall convertor. Randys Transmission.
689Hp-Custom Auto UCC Dyno
  #4
Old 11-13-2017, 10:29 PM
Private
Member's Gallery
Default
My truck have the factory bed hitch I have the gooseneck ball just not sure if it would be safe to pull a 45 ft trailer with the gooseneck hitch. I’m not new to towing just never towed a 5th wheel or something that long and heavy. Haven’t purchased the trailer yet but it’s in the near future.
  #5
Old 11-14-2017, 06:01 AM
sootie's Avatar
sootie sootie is offline
General
Member's Gallery
Default
Quote:
Originally Posted by Jeremy t View Post
My truck have the factory bed hitch I have the gooseneck ball just not sure if it would be safe to pull a 45 ft trailer with the gooseneck hitch. Iím not new to towing just never towed a 5th wheel or something that long and heavy. Havenít purchased the trailer yet but itís in the near future.
It would be a ton safer than towing it with a bumper hitch!
  #6
Old 11-14-2017, 06:53 AM
6.0 Tech's Avatar
Colonel
Member's Gallery
Default
Only thing i have heard with putting a gooseneck adapter on a fifth wheel, is that overtime it will crack the frame of the trailer, as the neck of the trailer isnt reinforced enough to have all the weight on such a small spot. Although, i did see a buddies ads fifth wheel neck crack using a fifth wheel hitch. So it may be more based on the trailer than how you actually tow it
__________________
  #7
Old 11-15-2017, 12:50 AM
Sergeant
Member's Gallery
Default
https://andersenhitches.com/Catalog/...onnection.aspx
This is the hitch I have, Iíve towed 6 different trailers, all different sizes and shapes, whether Iím in the mountains, making corners, or doing 95mph it is by far the smoothest most quite hitch I have found.
__________________
  #8
Old 04-08-2018, 07:32 PM
wyoostroker wyoostroker is offline
Private
Member's Gallery
Default
i have the same andersen hitch as above. i use it pulling a 37ft fifth wheel camper. the rv store would not let me install a gooseneck adapter because of the amount of the torque involved on the neck of the trailer.
overall, i actually like using the hitch. it is pretty simple to operate and can be installed or removed very easy.
  #9
Old 04-09-2018, 07:16 AM
Jason's Avatar
Jason Jason is offline
Major
Member's Gallery
Default
I have a buddy that pulls a montana 5th wheel with a short bed. Well, he has a long bed and a short bed, but the trailer has a curved nose, and he can get pretty sharp with it, no 90į turns, but it dpes fine in most all situations.
__________________
2015 Siren Red Tintcoat Tahoe LOADED
2014 Race Red Mustang GT M6, RACECAR
  #10
Old 04-09-2018, 03:58 PM
Koda22's Avatar
Koda22 Koda22 is offline
Lieutenant
Member's Gallery
Default
unless your trying to do something super crazy, i doubt you will really ever need to slide the hitch back....i pull with my short bed all the time, I do have a slider, and i think ive unlocked it maybe twice.....most of your corner are gonna be wide enough you wont need it.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
