Upfitter Switch Wiring in Box Lights
HobbyStock62
Mpls, MN
So, from my manual I should be finding 4 pass through wires, a yellow, green/brown, violet/green, and brown under the hood by the fuse box in the back left corner. I can not find those color wires anywhere there, I did find 4 wires taped to the harness though that I would imagine have to be them, but they are like white, white/red...not anywhere close to the colors that the book says, or anything I see online. Havent looked under the dash yet, but figure I need to get through the firewall before I deal with that anyways. Did they change some of the wire colors in 2015, or am I not looking in the right area for the correct pass through wires?
HeavyAssault
Middle, VA
The pass thru wires are closest to the driver's side hood hinge. I would need to pop the hood to check wiring colors.
HobbyStock62
Mpls, MN
Yes, left is drivers side. And holy crap, I thought people were just complaining about the wires being short. But whoever cut those to length needs a good throat punch. Its all wired in now.
