Go Back   PowerStrokeArmy > Power Strokes > 7.3 Tech
Reply
Thread Tools Display Modes
  #1
Old 08-10-2018, 05:59 AM
greyford1979's Avatar
greyford1979 greyford1979 is offline
Major
Member's Gallery
Default Crank, No Start
Well I went to start my truck this morning and it would't start. This week it started getting a little blue smoke at start up. Idled a little rough then smoothed out once warm. This morning it won't fire. Cranks fine, get white smoke out of the tail pipe, smells like fuel. Injectors? Truck ran just fine otherwise yesterday. No powers loss, nothing.
  #2
Old 08-10-2018, 06:34 AM
Zeb Zeb is online now
Sergeant
Member's Gallery
Default
Sounds like glow plugs/ glow plug relay. Take a test light and make sure you have power on the big stud that is closer to the center of the motor on the glow plug relay. Make sure you check it within 15-20 seconds of switching the key on. The other big stud should be constant hot.
White smoke when cranking and no start typically signifies fuel but not enough heat to start.
If the glow plug relay is dead and you really need to start it and it has a block heater, plug the block heater in for 30-45 minutes. That usually gets enough heat in the motor that it’ll start.
  #3
Old 08-10-2018, 07:38 AM
Major
Member's Gallery
Default
I'm at work right now so can't check anything, but I wouldn't think that a bad glow plug relay or glow plugs would cause such an issue in the summer time. It was almost 70 degrees this morning. And I've had it fire up in the winter before with a bad glow plug relay. When it cranks, it's like it almost wants to fire but won't. Cranks fast. Didn't pay attention if the tach moved or not. Can't find the cable for the laptop to check with AE. I thought maybe my IDM, but if I'm getting the white smoke, it's obviously commanding fuel. Wonder if my Adrenaline pump is having issues? Like I said it did have some blue smoke on start up that went away, which I never had before in the summer time. Didn't blow any smoke on the way home either, ran great. I was getting ready to install an Irate fuel system this weekend, looks like that's getting put on the back burner now, till I figure this out.
  #4
Old 08-10-2018, 04:47 PM
Major
Member's Gallery
Default
Just got home and decided what the hell, damn thing fired up instantly on first crank. However, now there is a slight blue haze at idle that won't go away. Tried switching to different tuners on my Hydra, and still the same haze. I installed a new IPR and all new orings on the PIS injectors when I did my heads, that hasn't even been 2 years yet.
  #5
Old 08-10-2018, 05:40 PM
Arisley's Avatar
Arisley Arisley is offline
Mod Squad
Member's Gallery
Default
Do yourself a favor and replace the PCm and IDM relays under the hood. I always kept a spare in my glovebox.
__________________
E99 ECLB Dually, 2010 bed, 2005 headlights, smoked clearance lights, 2001 cup holder.
365,XXX miles. Pure stock, sorta.
SDRCM #478
PSA Conspirator # 22
  #6
Old 08-10-2018, 05:53 PM
Major
Member's Gallery
Default
Will do, I know I've never replaced them lol. Just tested it again and fired right up. Idles smooth and test drove it. Runs great, no power issues, just gotta figure out the slight haze and why it didn't start this morning. I am lower on fuel than I normally would run since I was gonna install the fuel system. Question is, should I go ahead with the install, and while I'm doing it, remove the valve covers as well and check injectors? If I find the AE laptop cable I'll try to get some info as well. Can you check things like icp and other things on Forscan on the 7.3s? If I can't find my cable I might download that then and use a bluetooth OBD2 connector I have.
  #7
Old 08-11-2018, 08:29 AM
lincolnlocker's Avatar
lincolnlocker lincolnlocker is offline
General
Member's Gallery
Default
Quote:
Might have a plugged pickup tube if you let it go way low or it has lost prime. Get the mods done you want to do and get some good fuel in it and see if the problem persists... Blue haze usually would make me lean towards an oil issue but i have seen wierder things. The older trucks are more finicky with what bluetooth adapter you use. Id find the ae cable and monitor it asap. But yes, forscan does all that.
live life full throttle
__________________
00,f350,4x4,cc,drw, under the knife
01 rclb zf6,4x4,srw,ts tunes,bfaf,4"exhaust, 3800lb dd clutch
12,f350,4x4,cclb,srw, rudys/punch it d3lete tunes, donaldson bfaf.
  #8
Old 08-11-2018, 08:30 AM
Arisley's Avatar
Mod Squad
Member's Gallery
Default
Those cables can be bought anywhere, even at Walmart.
__________________
SDRCM #478
  #9
Old 08-11-2018, 08:33 AM
General
Member's Gallery
Default
Quote:
Even the obd cable?
__________________
  #10
Old 08-11-2018, 08:36 AM
Major
Member's Gallery
Default
Thanks guys. I checked the oil this morning, oil is good. Last changed it just under 2000 miles ago and don't need to add any. And the weird thing is, that this all just happened real suddenly. If turbo seals were going bad would it be white or blue smoke? I would really hope that's not an issue, turbo isn't that old lol.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
