Super duty drag link and TRE's on an OBS Dana 60?
chaselee
I've had the dreaded tie rod roll in my truck ever since I did the D60 swap and lift and I'm tired of it. There's a company called Carrick Customs that makes a steering kit for these D60 trucks that's supposed to fix the tie rod roll dead spot in the steering. The more I look at it, the more it looks like a Super duty setup to me. At least very similar. My question is if anyone has ever tried a super duty setup on an OBS truck. Or if it would even work. Any input is appreciated!
chaselee
It really does, but $600 for a drag link and tie rod is a bit crazy if you ask me. For sure not in my cards right now, which is why I was asking if anyone had ever tried to put SD steering on one
79jasper
skiatook, Oklahoma
You can get a insert. It's basically a bushing the goes in-between to keep it from twisting.
Ruffstuff has one. I thought someone made some before, specifically for fords.
Sent from my SM-G988U using Tapatalk
