Go Back   PowerStrokeArmy > Power Strokes > 2017+ 6.7 Aluminum Super Duty
Reply
Thread Tools Display Modes
  #1
Old 05-11-2020, 01:26 PM
Bryce_fow Bryce_fow is offline
Sergeant
Member's Gallery
Default Ccv
Are y’all running it to the exhaust or to a catch can I am on the fence on ether way
  #2
Old 05-11-2020, 09:22 PM
ncollins64's Avatar
ncollins64 ncollins64 is offline
Colonel
Member's Gallery
Default
Run down to a no limit catch can then out to a no limit Venturi in the exhaust
__________________
•2013 F350 CCSB PLATINUM
•08 F-350 CCSB 950/1493
Midwest Diesel, Elite Diesel, RCD, OUO, No Limit Fab, PMF Fab
•1997 F-350 7.3, srw, rclb, 4wd, 5speed (work truck)
•Past rig: 2000 F-350 ccsb, 1100 hp 6.7 cummins
  #3
Old 05-12-2020, 10:26 PM
Sergeant
Member's Gallery
Default
Is there my negatives to Ccv on a 6.7
  #4
Old 05-13-2020, 09:53 AM
Martin #6 Martin #6 is offline
Sergeant
Member's Gallery
Default
Any issues with just running the ccv to atmosphere, besides smelling possible oil fumes?
__________________
2017 F-250 4x4 CCSB Platinum
2008 F-250 4x4 CCSB Gone
  #5
Old 05-13-2020, 11:26 AM
Black AOD's Avatar
Black AOD Black AOD is offline
Colonel
Member's Gallery
Default
Quote:
That's what I have. You just have to drain the catch can every 5-10k
__________________
08' F350 6.4L EC/LB FX4 - long gone.
2017 F350 CCLB 6.7 SRW Platinum - WDI Built 6R, Exergy 10mm CP4, FASS 140gph, Taterbilt 6367 VGT, OUO & KING Suspension
  #6
Old 05-13-2020, 12:23 PM
Smokin 6.0 Smokin 6.0 is offline
Lieutenant
Member's Gallery
Default
I ran a CCV on my 6.0 for about 3k miles worst thing I ever did.. never had a drop of oil on the ground. Then did the reroute and boom oil leaks everywhere.. put it back stock and fixed the O-rings/gaskets that we’re leaking and not a drop again. Believe that the CCV can’t get rid of the crankcase pressure like it can when it’s being pulled back into the intake
__________________
My Rig - 2005 CCSB F-250 Lariat - Stock
Wife's Rig - 2016 Z71 Tahoe on 22’s
  #7
Old 05-13-2020, 01:42 PM
alewis alewis is offline
Corporal
Member's Gallery
Default
I run the absolute performance Ccv kit to atmosphere - no oil drips and no leaks.
I had the spe ccv kit and oil was everywhere is you even remotely ran it hard or towed.
  #8
Old 05-13-2020, 04:55 PM
Sergeant
Member's Gallery
Default
Weren't you originally experiencing the same results - no oil drips and no leaks - with the SPE kit?
What's the difference between the two kits to give different results? Is it because the Absolute Performance kit has a self servicing catch can canister assembly, with a integrated baffling chamber?
__________________
  #9
Old 05-15-2020, 12:31 PM
Corporal
Member's Gallery
Default
That’s correct... I didn’t get drops from the spe kit for the first 1500-2k miles. Then I had a trip through the mountains and some gooseneck towing that made the truck work harder and drips were all over my parking spot from then on.
So far, still no drips with the absolute kit and I’ve pulled a few heavy loads with it as well.
  #10
Old 05-16-2020, 06:58 AM
tomlin tomlin is offline
Private
Member's Gallery
Default
The CCV mod is a terrible idea on any vehicle. On a closed system you are simply burning the blowby oil mist. That's it. A diesel is an oil burner by it nature. Plus you get the added benefit of not smelling the noxious stinky fumes. On an open system you increase your chances of something getting blocked, either by insects, critters, ice, damage from road debris. Seen all the above on stationary generators that vent to the atmosphere. This is one of the reason Caterpillar is now offering CCV kits on its new generators. End of day this is a step backwards. It's similar to saying a draft tube on a 283 Chevy is better than a PCV system. It's not. Your asking for excess crankcase pressure and leaks.
__________________
2000 f350 super cab dually
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
