Cab Mounts Part # Verify
Central CA Foothills
Putting together a set of OEM cab mounts.
I have all located all a reasonable price except the top rear.
I have found some but they are likely non returnable once ordered. So I want to be sure I'm right on the part # before I pay $150 for 2 mounts. Cost not really the object at this point.
The most common part # is F5TZ-1000396-AB
The interchange to that is F4TZ-1000396A
Are these bot the top rear mount?
Thanks For your help!
Dave,
Thanks, I'm very familiar with that thread.
What I'm asking isn't in there. What I learned is the mounts part #
F4TZ- 1000396-A is the upper rear for a 91 to 94 F25O. Since the trucks havent changed much 80- 97, was hoping to find some info on this mount.
I w The various n line sources I found the upper mount to this one id The part # for the uppers that do seem to be available are listed for 92-94 trucks. F4TZ1000396A It also takes a different lower which is NLA.
Anybody have an idea of the difference?
gnxtc2
Bergen County, NJ USA
The F4TZ-1000396-A is for a 5.8L
The F4TZ-1000396-B is for all other engines.
Don't ask what the difference is as I have the slightest clue nor did my contact.
E0TZ-1000155-B is the lower that goes with the F4TZ-1000396-A
The F5TZ-1000396-AB is obsolete.
Billy T.
[email protected]
It appeared the F4TZ-1000396-A I saw a picture of would fit and had top and bottom steel "cups" to contain the rubber (likely making it firmer?)
So I said f it and ordered a set from Ford Parts Giant who listed them in stock.
Then they kicked it back as obsolete after all that scheming. Might have to go with LMC upper rear rubber. Or adapt something newer.
