Go Back   PowerStrokeArmy > Power Strokes > 6.7 Tech
Reply
Thread Tools Display Modes
  #1
Old 07-19-2018, 01:30 PM
rrkroll rrkroll is offline
Private
Member's Gallery
Default Going through hub assemblies too fast
Hi Guys,
I am wondering if there is something I should look for or something I need to replace when I change my front wheel assemblies again. I just replaced the hub assemblies on my 2011 f250 in March. I used MOOG lifetime guarantee bearings. Both of them are already shot, bad enough that there is approximately 1/2 of play at the top of the tire. These are not even 4 months old and have about 12000 miles on them. Before installing them the last time, I scotch brightened the bore in the hub, cleaned everything up really well and put just enough grease in that the o- rings would slide in well.
This truck has stock rims and stock size tires on it and has 99% highway miles on it. If you know of some trick that would increase the life of these please let me know.
Thanks. Ryan
  #2
Old 07-19-2018, 01:33 PM
morefuel's Avatar
morefuel morefuel is offline
Sergeant
Member's Gallery
Default
Did you check the movement after you put those in to see if it had been fixed? Could it be ball joints instead of bearing?
__________________
97 f?50, ZF-5 tranny, 6637, 3" downpipe 5" exhaust, PHP six position, 6.0 liter I/C, Polished 304 stainless I/C tubing, DIY exhaust brake, 2005 axle swap with 3.73, 280HP 551 ft. lbs as of May 2011. 2008 f250 6.4
  #3
Old 07-19-2018, 01:41 PM
Private
Member's Gallery
Default
Yes, everything was very tight in the front end after repair. And it was aligned the day after fixing it. The passenger side bearing is back off the truck and It is definitely junk again.
  #4
Old 07-19-2018, 01:47 PM
florida 6.0's Avatar
florida 6.0 florida 6.0 is offline
Lieutenant
Member's Gallery
Default
I switched to timken for this reason . The moog just don't last like they used to .
__________________
05 F350 , 9" 4 link with 37's on 17x12 , 4.56's , PHP FICM tunes , ******** SRL tune .
  #5
Old 07-19-2018, 02:43 PM
Private
Member's Gallery
Default
Might be what I have to do, I am going to give the Moog another shot but I will not be changing these every 4 months.
  #6
Old 07-20-2018, 11:17 AM
Jesse_01's Avatar
Jesse_01 Jesse_01 is offline
Major
Member's Gallery
Default
I always use Timken, SKF or OEM. SKF is about 4 times the size of Timken & is originated out of Sweden.
__________________
2006 Jeep, TJR
2011 F450, SCT X4
2016 F350, SCT X4
2018 Jeep, JLUR
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
