Baja Designs Squadron Pro driving lights
Barnbuilder
Waxhaw, NC
Came in yesterday, hope to get them on today.
Barnbuilder
Waxhaw, NC
Still pretty damn bright. I think the amber lens will pull off. Haven't tried it. And yes helps more in the fog. Usually a fog light has a better cut off in height as you want the light down low.
Jomax
Arizona
Does it scale down the brightness?
A bit, but not much. Also with Baja designs, the lenses interchange, And you can even change the light pattern with a lens change.
banksGTA
Etowah, Tn
Barnbuilder did you use your factory foglight pull switch or seperate switch? I think I may get me a set before I drive across country. Baja seems to out perform everyone else I've looked at.
Barnbuilder
Waxhaw, NC
Factory switch. The BD installation kit comes with plug and play wiring harness.
You won't be disappointed.
I got them from Mark @ Big Time Customz.
MorganM
SE Houston
Are you not able to aim them downward? BD would probably have a few ideas.
I want to buy something brighter but I'm leery of blinding traffic.
KC HiLites has a direct replacement that's SAE approved so I'm tempted to think they use a proper fog light cut-off.
Barnbuilder
Waxhaw, NC
Yes I can aim them down more might help some. I think I'm going to change lenses. Of you go on the BD website they show the light patterns for all the lights they offer.
