How to make 400 - 500 RWHP - 6.0L
TooMuch03
West Bend, WI
When was this and did you have any FICM tuning? I would thin Nitrous would put you way over 500 with that setup.
Nitrous won't get you a whole lot if you don't have the fuel to go with it. A little over 500 hp is about all you can get with the fuel from stock injectors.
its in the rear end
Where did you hear this? I just replaced my speed sensor, it is located in the extension housing of the transmission betweenthe transmissionand the transfer case.
Pizza pig
MD
false, there are people laying down 12 second times on stock injectors, which puts one well over the 500 hp mark nearing 600 all with nitrous of course.
Chucky1313
I got 05 with air aid intake 5" exhaust egr delete arp studs innovative extreme race tunes wanna try someone else's tunes who should I try next ?
Chucky1313
Is innovative good or did I waste my money because I did my research and they do most of the ppl in the diesel magazines
java
Texas
Innovative is one of the best. My truck always ran good with his tunes.
Chucky1313
Wow java in you sig your family owns all diesels made by ford which one you like the best ? 7.3,6.0,6.4,6.7?
java
Texas
I'd take my dads 6.7 any day. It is super comfortable to drive and with the spartan 200 horsepower tune it runs really good!
STROKEDOUT
NC
Vivian has good tunes. A little smokey IMO.
Sent from my ADR6400L using Tapatalk 2
smokedout250
harrisburg oregon
I made 436hp sotck injectors running 5" turbo back, S&B intake, no limit cold side and gearhead srlx... Hoping to have php ficm this spring And a mad hybrid turbo. Wanna see how much the stock injectors will do
Chucky1313
Is there power gains or loss swooping from '05 to '03 turbo or only real difference is whistle
Jeremyleggett07
Katy, Tx.
I was leanin to stage 2 MTW and 175s but I think I'm goin to go hybrid route and stock injectors as well with PHP tuned FICM as well
dieseljosh07
Georgia
That set up using a MTW stage 2, 175/100 injectors, airdog 150, a 58 volt FICM with PHP's atlas 80 tune and Innovative's extreme race dynoed at 548hp at our event this passed Saturday.
smokedout250
harrisburg oregon
That is what I plan to run eventually. I like that hp number as well!
