Go Back   PowerStrokeArmy > Power Strokes > 7.3 Aftermarket
Reply
Thread Tools Display Modes
  #41
Old 02-20-2018, 10:25 PM
Timmy's Avatar
Timmy Timmy is offline
Sergeant
Member's Gallery
Default
Quote:
Originally Posted by golfer View Post
on our cylinder head flow bench, a 6.4L head flows about 60% more CFM than a 7.3L head...stock to stock
HEUI is definitely an issue wrt to performance...but unless you want to run a solid/no coolant (7.3L) head, going to common rail isn't a gain.
if you want to run coolant in your 7.3L heads (ie, our CNC ported), you'd still be short on CFM compared to a stock 6.0/6.4L
it's a real nut kicker.
How would a set of stage 2 ported heads from y'all compare to stock 6.4 heads?
__________________
99.5 F350 SCLB ZF6 4x4, swamps 4/4s, FI gangster 472/87/1.0, Gen3, studs, springs, pushrods, fuelab, Dan K tunes and a whiff of Zex
95 F350 CCLB DRW 248k 2wd ZF5...stock tow pig
  #42
Old 02-21-2018, 02:41 AM
elrodalexander73's Avatar
elrodalexander73 elrodalexander73 is offline
Sergeant
Member's Gallery
Default
The guys who are using P-pump set-ups they have developed log style intakes, with individual runners, take a look at Smokin Addictions engine build.. Now that is way out of most individuals range of nature, but I've wonderered for quite some time what would some runner style intakes do for head flow and remote mount the turbo (much like the 6.5 diesel) and see what it does. I think some custom log style intakes would drastically improve head flow on a 7.3..
__________________
97 RC F350 FFD 250/200s, trans built by me, 35" All Terrains, alot of other "fun" stuff....
  #43
Old 02-21-2018, 06:36 AM
lincolnlocker's Avatar
lincolnlocker lincolnlocker is offline
General
Member's Gallery
Default
I wondered the same thing about how they achieve more flow for the mechanical setups.
__________________
00,f350,4x4,cc,drw, under the knife
01 rclb zf6,4x4,srw,ts tunes,bfaf,4"exhaust, 3800lb dd clutch
12,f350,4x4,cclb,srw, rudys/punch it d3lete tunes, donaldson bfaf.
  #44
Old 02-21-2018, 09:18 AM
golfer golfer is offline
Major
Member's Gallery
Default
Quote:
very close. within 5CFM
  #45
Old 02-21-2018, 05:08 PM
C'roy78stroker C'roy78stroker is offline
Sergeant
Member's Gallery
Default
Funny you mention that elrodalexander, that's my plan is to remote mount the turbo to passenger fender well. Much like Duramax setups. Then try to come up with a large capacity intake manifold. I've just finished removing the manifolds today. I'll be ordering the flanges and tubing soon.
__________________
1997 Eclb 4x4 auto
05 axles Gen 3
  #46
Old 02-21-2018, 09:58 PM
Timmy's Avatar
Sergeant
Member's Gallery
Default
Have y'all ever dyno tested the hp gain going from stock heads to your ported heads?
__________________
  #47
Old 02-25-2018, 05:20 AM
bluedge8's Avatar
bluedge8 bluedge8 is offline
Colonel
Member's Gallery
Default
Quote:
Technically, it won't change cfm in the head at all. But it may force more air through with boost, you would still have to clean up the flow IN the head.
__________________
'96 f350 cc lb 4x4, 6637, auto, 264k Pretty much stock
'03 chev 2500 crew cab duramax 395k bone stock
'02 F350 dually, Lariat, auto, banks everything, hydra on the way.
Quote:
Originally Posted by Arisley View Post
D3leted 6.0's are the best. D3lete them and replace with a Cummings.
  #48
Old 06-11-2018, 09:21 AM
Sergeant
Member's Gallery
Default
I'll be looking into this in case anyone was remotely interested in the original idea. If the stock crank rod journals can be destroked .250, a longer custom rod would be built, combine that with a .010 overbore, displacement would come out to a 6.9L ironically. I also ran numbers on the rod/stroke ratio (1.88) and bore/stroke ratio (1.04) with the altered setup. If the general ratio rules of thumb apply to any internal combustion engine then these numbers make it seem plausible. Plus with a longer rod, there would be more dwell time for the Piston near TDC which would also aid in the fuel injection window problem that we start to face with large fuel at higher rpm's. I'd like to get input about whether or not these calculations could be applied to diesel short block assemblies or not. Seems to me that rod ratio was a reason 6.7 Cummins crowd we're destroking down 6.4 liters.
__________________
1997 Eclb 4x4 auto
05 axles Gen 3
  #49
Old 06-18-2018, 10:32 AM
emev0l's Avatar
emev0l emev0l is offline
Sergeant
Member's Gallery
Default
Thatís the real question, Iím sure they have, they have their own engine dyno.
Iím 100% sure they make more power, Iíve just never seen any dyno results between 100% stock heads, a mild port job, and Swamps heads.
Iíve also not seen an insane rwhp gain between trucks with stock heads vs trucks with ported or Swamps/Crutchfield/Mondello heads.
There is a gain, but I donít see it taking my breath away
__________________
99 RCSB s468, 350/200, BTS, Twin Terminators, Crowers, A1000, Colt Cam, Headers, Cryo'd block, Girdle, De-lipped/Ceramic/Teflon Pistons, 05 front axle 666rwhp
Retired - 99 ccsb, s468, 238/200, BTS, Twin Terminator, ARP, 910, RR, Trutrac, 573rwhp
  #50
Old 06-18-2018, 11:56 AM
Major
Member's Gallery
Default
117hp
back in 2013 we did 280 something dyno runs, changing from stock heads/manifolds to CNC heads and headers, and tested about 6(8?) different cam profiles (with each inj/head iteration) we worked on with our cam manufacturer.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
Designed by Military Ltd
