(IL) nv4500
Cloverleaffarm
ridge farm, il
I have a nv4500/Bellhousing/couple pedals/NP231 Tcase (have to double check) that came out of a 97 2500 360 gasser with 115K miles on it.
picked it up from a buddy of mine couple of years back for a 5speed swap to replace my 68rfe but going another route
looking for $1,200
eastern Illinois/61870 area
Cloverleaffarm
ridge farm, il
That's where it'll end up eventually if need be. figured I could make a deal with Mark in exchange for something along the lines of a G56
SoGrand
MN
Do you still have this? Also are you sure the t-case is not a 241DLD or DHD? they never put a 231 in a 2500. If you still have this can you text me pics of the trans and t-case to 612-812-6861. I am interested.
Thanks
Cloverleaffarm
ridge farm, il
Good morning,
Yes I still have it in a pallet in storage. I will double check exactly which T-case it is so that I know and you know. I've had it for a couple of years and my memory isn't as good as it once was. i'm probably confusing it with a different manual setup that I have for another project
I should be able to get it out this weekend to get all the numbers off if it for specifics, and I will let you know when I do.
Zach
Cloverleaffarm
ridge farm, il
Nv4500 w/ bellhousing: 2wd 5.9 gas trans with around 115k miles out of a late 90s truck. 1-1/8" input shaft 10 spline with shifter/tower/couple pedals
has around 115-120K miles on it
nv271D: 29 spline 02-03 with 100k miles. Does not have the ID tag on it.
