New but not new. -24 offset and 305/55/r20. Tell me what you know.
Makingtime123
Hi everyone! Im new to the site. Just got a 06 f250 again. Just getting my toys back after wife and kids. Feels great. I want to fill my fender aftermarket flares up! Was thinking a set of 20x10 -24 offset with 305/55/r20. Anybody with this set up. Love to see some pics.
bft blue oval boys
Burlington, NC
Welcome to the site! How much are you lifted if any? That setup will probably look pretty good at stock height but of you lift it they will probably look too small.
Mine is a 6.4 but it'll give you some idea. This is that size tire on a 20x12 -44 wheel
bft blue oval boys
Burlington, NC
This is my dad's truck with a 20x10 not 100% sure on the offset but I think it is -24 or 27? Same size tire. You can tell it looks too small on his with his 3" leveling kit
Makingtime123
I have no lift. Your truck looks great. I was worried about clearance, but if you have no issues i shouldn't be to worried. I like that -44 look it makes me think maybe i should reconsider.
RedRice589
Ocala, Florida
Welcome! You will definitely have clearance issues with the 20x12 and your model year. A 20x10 wouldn't be too bad maybe minor rubbing on the inner fender liner which is an easy fix.
7.3powerstroke00
Brownwood
20x10 -19 offset + 1/4" spacers with 305-55 nitto terra grappler, 5200 lb coils with half coil cut off, rear blocks removed. Slight rubbing on fender liner after trimming at full left turn.
Makingtime123
Do you think a leveling kit will clear those 12" wheels with -44. With my flares im worried that a 10" wheel with -24 wont stick out enough.
black'n'blue
Your model year has smaller wheel wells than the 08's and up. I have an 05' with 22 x 12 wrapped in 305/40's, stock height and they barely rubbed at full lock on level ground. I think the overall tire size was 31.6"x11.8". Yours will be around 33.2"x12". You will definitely have rubbing issues at stock height and 12" wide rims. Even with a leveling kit.
